> F'ing Toyota
post Jul 24, 2004 - 5:00 PM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
I just took of my wheels to put my sideskirts on and I snapped of 2 studs and stripped another two. I have this problem before also, am I the only one or does toyota just make these easy to break???
Replies (1 - 15)
post Jul 24, 2004 - 5:45 PM
Anub1s
Joined Nov 27, '03
Sounds like its a problem with how you take off the lug nuts. What are you using? An impact gun or just one of those gay cross wrenches with the four sockets on them? I haven't had a problem with that before I don't know about anyone else though.
post Jul 24, 2004 - 5:59 PM
Element23
Joined Nov 17, '02
From Mission Viejo, CA
that has happened to me before. not that many lugs but before. i think its because auto shops, when they put wheels on cars they use impact guns which can cause cross threading. Time is also a factor, since you screw and unscrew them all the time (rotating tires, brakes, exhaust, etc.).
post Jul 24, 2004 - 11:57 PM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
I've just been using my torque wrench. I have used an impact wrench before also. No matter what I use at least one breaks every time. mad.gif
post Jul 25, 2004 - 1:30 AM
Junior
Joined May 5, '03
From Toronto
what do you torque your lugs to? You're probably put them on too tight.
post Jul 25, 2004 - 1:40 AM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
103 ft/lbs or in/lbs, I don't remember which one, but its what my manual says to torque them too.
post Jul 25, 2004 - 2:34 AM
95STHATCH
Joined Jun 21, '03
From FRANKFORT,KENTUCKY
76ft/lbs
post Jul 25, 2004 - 10:01 AM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
QUOTE (95STHATCH @ Jul 25, 2004 - 7:34 AM)
76ft/lbs
I'm looking at my manual now and it says 103 ft/lbs
post Jul 25, 2004 - 11:08 PM
Junior
Joined May 5, '03
From Toronto
76 is the correct torque. Most toyota's torque to this spec. I checked my manual and thats what it says. If you want send me your email and I'll send you the shop manual in PDF that gives lug torque specs.
post Jul 26, 2004 - 7:19 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
i have taken my wheels off about a billion times and not a single one has broke off. I use a break bar also and tighten them down pretty tight.
post Jul 26, 2004 - 11:02 AM
ConeTrouble
Joined Nov 25, '03
From Mizzeri
I autocross my 6th gen GT extensively. I probably change wheels and tires at least 10 times a month. I have never had a stud break. I bust them loose with the tool in the trunk, unscrew with a cordless drill. The lugs go back on with the drill, and then finish with a torque wrench to 80 ft/lbs.
I think you are over-tightening the lug nuts.
That said, I will say that I have had a couple of the nuts want to crossthread on me. I suspect that if you blammed them on with an impact (like a tire shop might do), that could cause you some grief. I have also had some of the nuts want to bind on me. Basically, what I did was to put anti-sieze on all the studs, and anti-sieze on the washer on the lug nuts (7th gen OEM GT wheels), and that solved the problem.
I don't know if I would recommend anti-sieze to everybody, though. If you don't diddle around with the car a lot, I would worry that they might work thier way loose. Since I do 2 or 4 tire changes every weekend during the summer, I don't sweat it, and just check it every month or so during the winter months.
post Jul 27, 2004 - 1:09 AM
RyCeCuBe
Joined Jul 4, '04
From 626 Ca
76ft/lbs
i broke mine once too...n the wheel guys told me it was only 45..then again, we do have different car's..but since then i only use my upperbody strength (i used to step on em with my feet frown.gif ) to tighten it and never had problems
post Jul 27, 2004 - 1:52 AM
Ale_lock
From New York City, NY
Why doesn't any shops ever use a torque stick on the air guns?! rolleyes.gif I wouldn't go to a shop & get my wheels removed if they dont own a set...
post Jul 29, 2004 - 5:39 PM
Verde97
Joined Aug 20, '03
From Kansas City
I used to install tires at Sam's Club and we used torque wrenches on the air guns. I remember vivedly that we used 80 lbs. for every kind of Toyota.
post Jul 29, 2004 - 6:12 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
QUOTE (Meonspeed @ Jul 27, 2004 - 2:52 AM)
at discount tires we use torque sticks bolting the wheels back on, and we torque all toyota cars at about 80ft/lbs.
This post has been edited by BLINKYxMUNKEY: Jul 29, 2004 - 6:12 PM
FlickR
post Aug 17, 2004 - 9:12 PM
toyotatech3
Joined Jul 30, '04
From colorado
every toyota from the mid 80's too now torque's at 80ft/lbs except the new land cruisers! i take two or three sets of wheels off a day and put them back on with an impact gun and a torque stick, and have never had a problem with breaking them or crossthreading.
Lo-Fi Version Time is now: August 25th, 2026 - 7:18 AM
