> Advancing Ignition Timing., Can anybody tell me the right way?
post Jul 26, 2004 - 10:49 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
Several times I've heard on these boards that advancing the timing a few degrees can be beneficial to both your fuel consumption and throttle response. Can anybody tell me the right way to advance your timing?
Ive heard people say to use a timing light and to adjust it on the distributor, but I need some explanations of what a timing light is/does and the best method to adjust timing. Thanks in advance guys.
Replies (1 - 10)
post Jul 29, 2004 - 6:13 AM
Silvan
Joined May 7, '04
From Leeuwarden, Netherlands
Hi,
Maybe this comes in handy....
http://www.toyotacelicaonline.com/timing.htm
Gr, silvan
post Jul 30, 2004 - 5:25 PM
Silver94CelicaOw...
Joined Oct 13, '02
post Jul 31, 2004 - 5:47 AM
Hanyo
Joined Aug 16, '03
From Bay area
it says to short TE1 and E1
do our cars use the same terminals?
7afe terminals are?
post Jul 31, 2004 - 10:48 PM
Hanyo
Joined Aug 16, '03
From Bay area
OK i confirm.. TE1 and E1 are the same for the 7afe.. but you cant adjust the timing on the 7afe engine, because you cant turn the distributor.
post Aug 1, 2004 - 1:13 AM
FAQdaWorld
Joined May 24, '03
From Milton, Delaware
Um, yeah you can.... You have to loosen a bolt on it, and then it will turn
AIM : FAQdaWorld
post Aug 1, 2004 - 9:42 AM
mikew04
Joined Feb 19, '04
From austin tx
It says he read that 1 degree adds 2 whp... i cant see how that is true
post Aug 1, 2004 - 10:31 AM
ghostdog
From ny to philly
QUOTE (FAQdaWorld @ Aug 1, 2004 - 2:13 AM)
timing can be advanced on 94-95's because they have OBD-I. 96+ have OBD-II and therefore the distributor can't be moved, and even if it could the ecu would automatically retard back the timing.
post Aug 1, 2004 - 11:52 PM
Hanyo
Joined Aug 16, '03
From Bay area
horrible.. i hate you obd II..
post Aug 6, 2004 - 2:48 PM
mikew04
Joined Feb 19, '04
From austin tx
so how much power, if any, would this give you?
post Aug 6, 2004 - 2:58 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
You can actually gain pretty decent performance from doing this. But you will start causing damage to your engine sooner. You will probably get knock or pinging from advancing your timming because your fuel will lean out. I wouldnt mess with it. I guess if you were going to the track and ran some high octane gas you could advance it a few degree's. I played around with this some on my corolla.. There were a noticable difference in performance when i advanced it alot. Then i retarded it and boy was it doggish.
This post has been edited by bufferdan: Aug 6, 2004 - 2:59 PM
Lo-Fi Version Time is now: May 18th, 2026 - 1:06 AM
