> i dont think making ur own MBC works, help
post Jul 31, 2004 - 8:29 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
well i made my own MCB. as stated here. http://www.geocities.com/chmwatson/FAQs/mbc.html
my psi goes up to 9 or so then falls to 5 once the turbo has reached the end of spool up. get what i mean. ill give it full throttle it will go to 9 then its drops to 5. haha w/e it happns could it be sumthing else like a leak? but wouldnt a leak not allow it to go to 9 in the first place?
post Aug 1, 2004 - 10:58 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i lied i fixed the problem had to dril a breather hole. and i mad my own MBC for $12 works great now smile.gif
post Aug 1, 2004 - 11:10 PM
hyp3rk1d
Joined Sep 22, '03
Nice also is it in the cockpit of your car.. so you can just adjust it if you wanna cruise or race??
post Aug 2, 2004 - 9:05 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
nah because if u ran tube that long the tube would flex and ballon causing boost creep so i hear.
post Aug 2, 2004 - 9:08 AM
hyp3rk1d
Joined Sep 22, '03
so what will u be doing?? leaving your boost at like 8psi all the time.. Or turn it down for cruising??? Also can i see a picture tongue.gif
post Aug 2, 2004 - 9:11 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
right now its at like 7.5 psi in first through 4th then 5th gear brings it up to around 8.5 it weird. turbo is alot louder. bov is louder. and the car is quicker. love it. whil i was tuing hte MBC i went up to 13psi. was amazing. but i was ther for a fraction of a second before i let off the gas.
post Aug 2, 2004 - 9:19 AM
hyp3rk1d
Joined Sep 22, '03
Nice
post Aug 2, 2004 - 7:31 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (x_itchy_b_x @ Aug 2, 2004 - 6:11 AM)
there is more load on the engine in 4th and 5th
its very normal to hit higher boost in those gears, especailly with a MBC
btw i made a similar one for my friends 240z with a 280zx turbo engine swap. except the one i made is more simple and can make for much higher boost levels than stock, lol, but of course i lengthened the wastegate actuator rod so that it will run only like 3psi with out the mbc
now if only we can get the damn engine to start.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Aug 2, 2004 - 8:05 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
QUOTE (97sccelica @ Aug 2, 2004 - 8:31 PM)
yeah i did the same with my actuator rod. i ran stock 5psi. cool about ur friends car. so yeah point of thsi thread i guess ucan make ur own for $12 instead of paying for one.
post Aug 3, 2004 - 3:09 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
if you're going MBC, you might as well make it. it truely is a waste of money to buy one.
now electric boost controler, thats totally different
post Aug 3, 2004 - 6:43 AM
hyp3rk1d
Joined Sep 22, '03
how do u make it so u can run stock like 3 or 5 instead of the preset 9
post Aug 3, 2004 - 7:20 AM
What preset 9? 3s?
Just turn the boost down and it'll go down.
post Aug 3, 2004 - 8:59 AM
boosted_K2
Joined Aug 30, '02
From Michigan
8-11psi is standard, mine runs consistant 10PSi at WOT in 2nd-5th, 1st usually only hits about 8
No but I don't buy it
Cause I'm...
post Aug 3, 2004 - 9:01 AM
boosted_K2
Joined Aug 30, '02
From Michigan
also, did you do a ball and spring or restrictor MBC??
EDIT: NM, the article is for a ball and spring style.
This post has been edited by boosted_K2: Aug 3, 2004 - 9:03 AM
Cause I'm...
Lo-Fi Version Time is now: August 31st, 2026 - 5:02 PM
