Feb 27, 2003 - 12:28 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
Ok, I am gonna get a DR CAI.
There is aluminized steel, and aluminum. I figured aluminum is better, but a friend of mine said it would heat up more than the aluminized steel. BUT, i wonder if the aluminized will rust? Also, has anybody made their own CAI and been hapy with it, and finally, who has a DR CAI, and how do you like it? |
Feb 27, 2003 - 9:29 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
an east cheap way I've seen a CAI without the metal pipe was this guy who removed his box, but kept the hard ruuber tube from the intake. he just attached a K&N to it. He said it worked fine. Don't have to worry about rust, but how would yout stuff rust anyway? I didn't think water got into the engine bay all that much
Feb 27, 2003 - 12:01 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
Like igotta said, what your thinking of is a short ram intake, a CAI involves running a tube, metal or rubber, out of the engine bay away from heat. Usually a cai is placed in a wheel well or housed in the front of the bumper. -------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Feb 27, 2003 - 5:53 PM
Enthusiast ![]() ![]() ![]() Joined Nov 18, '02 From Texas Currently Offline Reputation: 0 (0%) |
I've got the cheap set-up for now (filter on the stock tube and it works well), but I'm planning on making a CAI. There's a how-to on the process of making one if you're good with that kind of stuff.
However, if you'd rather buy it, the Dr.CAI looks like the definite way to go. I sent an email to Dolecek about the differences. It was a while back, but I believe he said that the Aluminized Steel CAI could rust and it would be better to paint it, but for $50 more, you could have aluminum, which is also lighter (if that really matters to you). Hopefully this might help you somewhat. |
Feb 27, 2003 - 8:27 PM
Enthusiast ![]() ![]() Joined Nov 8, '02 From Narragansett,RI Currently Offline Reputation: 0 (0%) |
I put a filter on my intake with just keeping the rubber hosing. I used PVC piping to fit the K&N on. It worked just fine but I'm soon going to be upgrading to a CAI. Mine works just like a short ram.
Mar 2, 2003 - 1:59 AM
I believe heat soak is really bad on aluminum though.
Mar 6, 2003 - 4:05 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
I have the Dr CAI and i can't complain..if you want pics of it just IM me on PlatinumImpact and i'll send you all that I have
Mar 6, 2003 - 6:24 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Sep 5, '02 From Phoenix, AZ Currently Offline Reputation: 0 (0%) |
I got a CAI and i think it's way better than PVC pipe or using your old tubing. It's powder coated also, so i don't have to worry about it heatin up.
Mar 7, 2003 - 1:29 AM
I'm just gonna make my own from exhaust piping. Also, i was trying to figure out how to get the filter in the fender, and I don't see a way to do it. The Radiator reservoir is in the way. I wonder if i could get a pipe through where the stock intake gets air.
Mar 7, 2003 - 7:00 AM
Your probly right. I thought someone said that powdercoating helps with heat soak. Oh well, i'll just buy some wraps for headers and use it on my CAI.
Mar 8, 2003 - 1:12 AM
That's what I'm gonna do. (wrap) Also, i wonder if DR powder coats inside the pipe? If not, it could rust-->major major problem. I wonder if iron oxide helps performance, lol
Mar 8, 2003 - 3:05 AM
Well it would just rust to the point where the outside is powder coated, so you would end up gettin a larger intake and more air capacity.
Mar 8, 2003 - 3:06 AM
always good lol
Mar 8, 2003 - 3:18 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) |
i may have just had a brilliant idea... -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Mar 8, 2003 - 3:22 AM
oh and as for aluminum heatsoaking yea it is bad, it has a thermal conductivity of 240 J/(sMC^deg.) in reference stainless steel has a conductivity of 14... the ideal material has 0.00 conductivity. thus bringing me to my ingenious idea...
EDIT: just looked this up at dow QUOTE: "Thermal conductivity - Values usually range from 0.330 to 0.515 x 10-³ gr-cal/sec/cm²/cm/°C." thats for silicone rubber good stuff, thats y its used for couplings... (silicone rubber is NOT part of my plan, just seeing its conductivity for coupling reference) ANOTHER EDIT: for any of you who are wondering why the units for my #s are different from dow's units they arent different. gr=1 gram so it cancels, 1 cal = 4.186 J, sec = s, M = cm^2*cm*rho, and obviously deg celcius = C^deg. This post has been edited by K2_Celica: Mar 8, 2003 - 3:33 AM -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
Mar 9, 2003 - 11:55 PM
I think you learned about heat soak on a few materials today and felt like a lecture. Either way, this is my performance thought. Whithin a year I will: Get a DR CAI, header, and might get the greddy exhaust. (most likely have pipe made for my car) then I'll get a high flow cat. Why keep a cat? so my car isn't LOUD!!!!!!
Mar 10, 2003 - 2:47 AM
just get a muffler that has a silencer
Mar 10, 2003 - 11:49 AM
nope actually i had just finished my physics HW for the day, read this and since i still had it out, flipped back a few chapters and got some #s then followed up with a trip to the dow chemical website... im starting to draw out my prototype of my idea for a CAI, if i get done and it actually works like it would on paper, i may try the same sort of idea for a headerback piping... im still trying to figure out what materials to use... anyone know what the temp under the hood is at on average? celcius ferenheit or kelvin doesnt matter... -------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
| Lo-Fi Version | Time is now: June 11th, 2026 - 9:51 AM |
