Feb 27, 2003 - 1:21 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 12, '02 From New Jersey Currently Offline Reputation: 0 (0%) |
Yes, I can get you a full set for $230.00 plus shipping
(he is referring to just the front , with brake pads) Brembo cross drilled and slotted. Just give me a call when you are ready. Thank you. Wood -------- so my question is are my rotors hubbed..i asked my friend how long it would take to install and he said "if your rotors are hubbed..2hrs." and he wanted me to post on here and find out..can someone give me an idea? |
Feb 27, 2003 - 2:40 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Sep 5, '02 From Phoenix, AZ Currently Offline Reputation: 0 (0%) |
Fuk that!
You can get a full set front/back for under $200 off ebay. |
Feb 27, 2003 - 5:20 AM
Enthusiast ![]() ![]() ![]() Joined Sep 27, '02 From UK Currently Offline Reputation: 1 (100%) |
WERD! eBay - Mastergrade - set of 4 drilled / slotted Brembo discs for ST or GT for under $200 + shipping. FYI: My set-up (that is, I've ordered it all but waiting for it all to arrive) - 4 Brembo discs (as above); - EBC GreenStuff front; - EBC Reg90 back. BTW: If you have more money to spend then I suggest you look into KVR discs and pads. |
Feb 27, 2003 - 11:20 AM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 27, '02 From Sleep in Warren chill in clinton twp, works/school in detroit Currently Offline Reputation: 1 (100%) |
hope ure brembos doesn't rust tho
Feb 27, 2003 - 2:48 PM
Enthusiast ![]() Joined Aug 31, '02 From Bay Village, OH Currently Offline Reputation: 0 (0%) |
would you be able to get just slotted? Cross-drilled and slotted seems like it is a waste of money (too much pad wear, too little stoppage difference)
Feb 27, 2003 - 3:44 PM
i have an ST so i can only get them for front
Feb 27, 2003 - 3:48 PM
and i searched for those mastergrade rotors you are talking about, couldn't find them on ebay??? |
Feb 27, 2003 - 4:55 PM
Enthusiast ![]() Joined Dec 20, '02 From New York Currently Offline Reputation: 0 (0%) |
Only slotted will give it more wear. The Cross-drilled will jsut cool it down. Slotted gives it a extra bit. Where cross-drilled just cools it more. That's what I heard.
Feb 28, 2003 - 2:12 AM
Enthusiast ![]() ![]() Joined Jan 9, '03 From Concord, NC Currently Offline Reputation: 0 (0%) |
when searching on ebay just type in "94 celica" and you will get a nice list, mostly lights but some other good stuff, too.
Feb 28, 2003 - 3:23 AM
When you press your brakes the friction from the brake pads causes a gas to build up between the pad and rotor causing poor braking. If you have drilled rotors then the holes give a place for the gas to escape and also helps with cooling the pads. If you have slotted, the slots lift the pad up and scoops all the gas out causing even better braking and cooling of the pads. Throw them together and they create awesome braking power, or not. In theory they would, but i don't know from experience.
Mar 1, 2003 - 10:33 AM
Enthusiast ![]() Joined Feb 18, '03 From UK Currently Offline Reputation: 0 (0%) |
Be careful of EBC i had them on my BMW went through two sets of discs in less than a year, they arent very good when the weather is cold either. Thats only my experience. |
Mar 2, 2003 - 12:28 AM
are the stock rotors hubbed?
Mar 2, 2003 - 1:12 AM
Enthusiast ![]() Joined Jan 20, '03 From Denver, co Currently Offline Reputation: 0 (0%) |
No, your rotors just slide off. It might take a little muscle, depending on where you live and how much rust is on them. If they were hubbed, it would be easier to change the front bearings.
Mar 2, 2003 - 9:26 PM
![]() Enthusiast ![]() Joined Dec 1, '02 From minneapolis Currently Offline Reputation: 0 (0%) |
from what i have heard, crossdrilled are a little more effective for cooling than slotted. the crossdrilled aren't quite as long lasting as slotted though. but i don't think that would really matter unless you are strictly racing.
crossdrilled just look so sweet though. i think that is what i would go with. |
Mar 2, 2003 - 11:53 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
Just curious. If i got all 4 rotors, all i would need is the caliper and the back plait to make my car 4wheel disk?
Mar 3, 2003 - 7:25 AM
and the cables for the rear, or was it tubes?
Mar 4, 2003 - 12:06 AM
I thought the drum tubes would work?
Mar 4, 2003 - 12:46 AM
Is that all it consists of to get rear drums converted to disc?
Mar 4, 2003 - 1:07 PM
well i just got my green stuff and kvr's put on and I must say there a very noticable difference in stopping now
i dunno how long it will run tho but so far me and my lil sis (im force to teach her how to drive noticed the difference -------------------- |
Mar 4, 2003 - 3:45 PM
i dread the day i have to teach my sister how to drive..
| Lo-Fi Version | Time is now: August 26th, 2026 - 7:06 PM |
