Aug 10, 2004 - 1:36 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
whats up guys, I've had some skirts for a while and finally have some money laying around to have them painted, but I was wondering if this is an easy instal I could do myself, and just have them painted. I test fitted the skirts, they seem to be pretty tight, the area I was having problems with was the area in the door jamb. does anyone have any type of tips or tricks to installing skirts, or should I just pay a professional? Thanks for your help
-------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Aug 10, 2004 - 6:41 PM
Enthusiast ![]() ![]() ![]() Joined Aug 20, '03 From Kansas City Currently Offline Reputation: 0 (0%) |
If you're skeptical, I would just have a professional do it.
Aug 10, 2004 - 7:40 PM
Enthusiast ![]() ![]() Joined Nov 26, '03 From McKenzie, TN Currently Offline Reputation: 0 (0%) |
I'd let someone else put them on. Doesn't sound like you know what your doing.
Aug 10, 2004 - 8:39 PM
Enthusiast ![]() ![]() Joined Nov 29, '03 From Hampton, VA Currently Offline Reputation: 0 (0%) |
What type of skirts are they? Basically you need to fit them, and then glue and screw them to the car. Check out this forum:
http://www.6gc.net/forums/index.php?showtopic=14561 I gave a how-to on putting on a kit as a whole, but the info is still good for just sideskirts. If you're putting on invader skirts, there's a top lip that lays on the bottom section of the door jam (at least mine did). I found that there was no way to put the plastic trim back on with that lip there. Is this the problem you're talking about in the door jam? If so, do like I did and cut off that lip and smooth the rest of the skirt into the door jam. -------------------- ![]() |
Aug 10, 2004 - 11:27 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 25, '03 From cranston RI Currently Offline Reputation: 0 (0%) |
man.... i just drilled a hole through my sideskirts and car, and popped a screw in
Aug 11, 2004 - 6:53 AM
I wish I had done that. It's been over a month and I'm still doing body work on my car. I guess I'm just picky. If you do mold the skirts into the door jam, it does look very nice. The you can put the plastic back down and the skirts look like they were always part of the car. -------------------- ![]() |
Aug 11, 2004 - 9:14 AM
i left that piece of the skirt on and i could fit my plastic piece on still?? just removed the clips in the middle of the plastic piece
Aug 11, 2004 - 12:54 PM
thanks for the info guys
| Lo-Fi Version | Time is now: August 4th, 2026 - 2:06 PM |
