> Does flywheel really get our Celica faster so much
post Aug 11, 2004 - 3:02 AM
ST-204
Joined Dec 21, '03
From Lynnwood, WA
post Aug 11, 2004 - 3:18 AM
Doge
Joined Dec 2, '02
From Portland, Oregon
It will make it rev more quickly, which means better throttle response. It will also make the car harder to start from a stop. It is a lighter rotating mass, which makes it easier to stall.
post Aug 11, 2004 - 3:23 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (ST-204 @ Aug 11, 2004 - 8:02 AM)
Yes... a Stock Celica will lose to a Stock Celica with a light flywheel...
post Aug 11, 2004 - 4:01 AM
ST-204
Joined Dec 21, '03
From Lynnwood, WA
So as an example in 0-60mph, how fast does the Celica with lighter flywheel faster than the stock Celica??
1s or even 1.5s??
post Aug 11, 2004 - 4:10 AM
Doge
Joined Dec 2, '02
No way would it be that much of a difference. It will just give the car a more responsive feel and slightly better acceleration. Probably not worth it unless you're going to go pretty in depth to get some performance numbers out of your car.
post Aug 11, 2004 - 6:17 AM
It transfers more hp to the wheels because the engine has to rotate less mass.
post Aug 11, 2004 - 9:31 AM
shid
Joined Jan 8, '04
From LA
A flywheel does not increase the hp your engine puts out- it allows for more hp to the wheels, and faster rev cycle... SO, you can get up to that peak rpm faster; and have more hp on the ground.
It does nothing to increase the power in your lower rpm range- which many people think it does. It just rockets you through the lower rpm range
post Aug 11, 2004 - 10:18 AM
Your car will be faster once it's moving, but whether or not it's worth it is kind of a toss-up. I don't like my JUN lightweight flywheel at all. It's 9 lbs. compared to the stock 18, and is far too light for the street. I have to rev up the car to around 1,600 RPM or so before I can go from a stop or the car shudders and shakes really badly. My car is also slower off the line with the 4A-GE and the lightweight flywheel than it was with the 7A-FE and the stock flywheel.
So hopefully tonight or tomorrow night my OEM flywheel and new clutch kit are going into my car. smile.gif I'm just horribly sick of the lightweight flywheel.
post Aug 11, 2004 - 10:35 AM
turboinduction
Joined Feb 25, '04
From Wisconsin
Would you suggust a middle weight - like 11lbs? I was thinking this but I've really never driven a car with a lightweight flywheel before. I'm very unsure of the advantages/disadvantages of it.
post Aug 11, 2004 - 11:32 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (Coomer @ Aug 11, 2004 - 3:18 PM)
You interested in selling that flywheel coomer? ;]
post Aug 11, 2004 - 12:02 PM
QUOTE (Kwanza26 @ Aug 11, 2004 - 9:32 AM)
Yeah I am...Assuming I don't absolutely hate how much slower the car is without it, I'm going to sell it. I'll send you a PM once I pull the flywheel out of the car. smile.gif
post Aug 11, 2004 - 7:19 PM
RedSunCelica
From San Diego CA
QUOTE (Coomer @ Aug 11, 2004 - 10:02 AM)
ive driven a 5th gen with a lightened flywheel once and damn nice difference when moving thru the gears and shifting feels really nice.
post Aug 13, 2004 - 8:52 AM
tufy
Joined Dec 3, '03
From Cyprus
QUOTE (Kwanza26 @ Aug 11, 2004 - 8:23 AM)
fly wheel doesnt make that difference that one car can pass other. and doesnt worth money that you are goin to pay. and its unconfortable when drivin at low rpms.
here is a discustion form that you can learn advantages and desadvantages of light weight fly wheel.
http://forums.beyond.ca/showthread/t-10041.html
Lo-Fi Version Time is now: August 30th, 2026 - 8:02 AM
