Aug 11, 2004 - 10:15 PM
Enthusiast ![]() Joined Sep 18, '02 From Masachusettes Currently Offline Reputation: 0 (0%) |
After paying a redicleous 788 to get a new clutch and a oil change my car won't start. I picked up my car from the shop today. I was excited because my clutch was worn out for 6 months and i could barley do the speed limit. i drove to the mall and back. when i got home i drove down the street to the store and back. after letting the car sit in the drive way for 3 hours i started it up and low and behold it wouldent start. WTF. The car won't turn over. My deep cycle optima batterie is fine 12.84v. I checked all the fuses that i could see. the car makes no noise when i try to start it not even the dead battery sound. can anyone help me please. i am calling the place i got the car fixed tomarrow first thing in the morning. the only problem is that the car is too low and won't fit on a tow truck unless i raise the suspension what fun
Aug 11, 2004 - 10:26 PM
you need to explain in full detail what the car does when u turn the key and step on the clutch.
Aug 11, 2004 - 11:39 PM
Enthusiast ![]() ![]() ![]() Joined Mar 20, '04 Currently Offline Reputation: 3 (100%) |
did you get a oem clutch if you did it seems like a pretty expensive price to be paying. did mines for 500
Aug 12, 2004 - 12:02 AM
need more info.... but sounds like it could be that alt.
Aug 12, 2004 - 12:31 AM
Enthusiast ![]() ![]() ![]() Joined Jul 27, '04 From phoenix az Currently Offline Reputation: 0 (0%) |
i agree i also think its the alt. there also might be no water in the batt check that too.
Aug 12, 2004 - 1:27 AM
Enthusiast ![]() ![]() ![]() Joined Oct 24, '03 From Cyprus Currently Offline Reputation: 0 (0%) |
Also it could be a loose battery connection or blown some fuses.
Aug 12, 2004 - 2:01 AM
clutch safety switch broke maybe?
-------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Aug 12, 2004 - 4:27 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
He said his battery is putting out 12.8 volts. Check your cables and make sure they are on tight maybe jiggle them a little and try it then.
Aug 12, 2004 - 4:54 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
If the engine isn't even turning over, and you power is all hooked up correctly, it is almost certainly the starter. Its not the alt; you dont need the alt to turn over the engine, only to power the car once you have already started.
I supposed its possible that the new cluch somehow is impeding the turning of the engine, but that is very unlikely. |
Aug 12, 2004 - 5:21 AM
If everything is hooked up correctly on your battery. Take a hammer and tap on the side of your starter.
Aug 12, 2004 - 7:26 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
Thats what i would say. Are you getting a click sound when you turn the key? If you are then its not the clutch safety switch. It would probably be the starter selinoid on the starter. -------------------- ![]() |
Aug 12, 2004 - 8:11 AM
not true on the celica... -------------------- |
Aug 12, 2004 - 8:40 AM
Enthusiast ![]() Joined Dec 2, '03 From Virginia Currently Offline Reputation: 0 (0%) |
I would check to make sure that the clutch is disengauging. You might be able to see the top of the fork on the st, I'm not sure. On the 5s, its in the top front of the transmission with a boot covereing the end, and will have a little cylinder connected to it, with a hard line that runs back to toward the fire wall.
Check grouding and make sure they connected them all again. I can't remember how many there should be, but probably one from the transmission and starter. Check clutch switch, its at the back of the clutch pedal. just disconnect the connect and hook it to an ohm meter. Have someone step on the clutch and fully depressed you should get continuity, and when the release the pedal an open circuit. |
Aug 12, 2004 - 9:21 PM
i got it fixed today the stupid guy didn't clip the starter wire in properly do it got loose. thats the last time i bring my car there.
Aug 12, 2004 - 9:23 PM
glade to hear you got it fixed... -------------------- |
Aug 12, 2004 - 9:54 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 27, '02 From Derry,NH USA Currently Offline Reputation: 9 (100%) |
Optima Batteries are Maintenance free....I have one myself..A Yellow top. -------------------- |
| Lo-Fi Version | Time is now: August 31st, 2026 - 7:10 AM |
