> MR2T ECU, will it work in an ST swap?
post Aug 12, 2004 - 1:50 AM
Yota
Joined Feb 27, '04
From Illinois
I am buying an MR2T clip and I need to know if the ECU will work with everything in my ST (guage cluster and stuff). I was told that it might be difficult or impossible to use this ECU and I want to check on that before getting into the project.
Also, Will the throttle linkage from the MR2T work in my car, or can I still use my 7AFE? If neither of those work out, which is the one I shall need?
Replies (1 - 4)
post Aug 12, 2004 - 6:14 AM
Its the same as swapping in a Celica ecu, you need to rewire everything.
post Aug 12, 2004 - 6:51 PM
boosted_K2
Joined Aug 30, '02
From Michigan
u want GT throttle linkage. the MR2 ECU should work fine, you will probably have to mesh some of the connectors though between the ECU wiring and the connector for the accessories/displays.
No but I don't buy it
Cause I'm...
post Aug 13, 2004 - 12:19 AM
Yota
Joined Feb 27, '04
From Illinois
what do you mean by 'mesh'?
post Aug 13, 2004 - 12:22 AM
Yota
Joined Feb 27, '04
From Illinois
Also, do I need all of the GT motor and transmission mounts?
Lo-Fi Version Time is now: August 31st, 2026 - 5:30 AM
