> Building custom boxes w/ fiberglass, how long would it take?
post Aug 12, 2004 - 3:44 PM
acenova
Joined Dec 21, '03
From Portland, OR
HOw long would it take for me to build a custom shelf (not box) to replace the one in my hatch, about the same size, using fiberglass and plywood??? I guess I should ask if anyone's done it yet, but how long does fiberglass take to dry and what not, and is it really easy to work with or a B*&$H?!
post Aug 12, 2004 - 4:29 PM
It's kind of hard to work with at first, but you get the hang of it. I'm not sure what exactly you're planning on having your shelf be like, but it probably wouldn't be too hard.
You and Amy and Aaron should come up here sometime soon, and I'll show you what fiberglass is like to work with if you want. smile.gif
Oh, and lately it's been taking the fiberglass about 45 minutes to dry for me. It's really, really hot up here and I haven't been mixing the batches with less MEKP, so that's why it's so quick to dry right now. Ideally, it should take 2 hours for each layer of fiberglass to dry.
post Aug 12, 2004 - 4:58 PM
acenova
Joined Dec 21, '03
From Portland, OR
wow...nice man. maybe we'll have to take that trip. Definitely would like a lesson in fiberglass working. I have some plans for my next celi involving some of that so that'd be great. Thanks for the info.
post Aug 12, 2004 - 5:19 PM
gtcelica94
Joined Apr 4, '04
fiberglass is easy to use , tip* spray wd-40 on ya gloves so the fiberglass dont stick to them
post Aug 12, 2004 - 5:27 PM
QUOTE (gtcelica94 @ Aug 12, 2004 - 3:19 PM)
I'll have to try that next time...I've never heard of that before. smile.gif
post Aug 12, 2004 - 10:32 PM
chucho
Joined Mar 23, '03
From New Orleans
i really want to make a FG box for my SL7 before the nopi show but i wont have enough time frown.gif i dont think i will extremely busy
post Aug 13, 2004 - 12:18 AM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
wd-40.. thats a great tip, thanks dewd
post Aug 13, 2004 - 11:23 PM
celimanST
Joined Nov 15, '03
From mississippi
FG is easy to work with but the most important thing to remember is TAKE YOUR TIME, Don't rush.
William
post Aug 13, 2004 - 11:34 PM
Junior
Joined May 5, '03
From Toronto
i don't know why you want to use ply wood. FG is easy to work with once you realize what you're up against. I would recomment taking some chicken wire and make a basic shape. Fibre glass right over it untill you have your desired thickness. Sand and shape. Use a fine finishing putty to fill high and low spots. And paint.
post Aug 16, 2004 - 3:22 AM
creis
Joined Jan 10, '04
From Shoreline, WA
IT TAKES A LONG TIME, If you want it right. wd-40 i never though of that, thanks. Its not a b$t@h, actualy kinda easy but time consuming.
my tips: get wood doweling (thin wood, looks like small pipeing) to make the shape you want, then cover it with cloth and fiberglass over that. Also make it thick and use planty of resin, the thicker it is the more you can sand, giving you plenty of room to get the exact shape and texture you want.
post Aug 16, 2004 - 1:41 PM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
http://web.njit.edu/~cas1383/proj/main/ i hope this will help u
post Aug 16, 2004 - 1:49 PM
acenova
Joined Dec 21, '03
From Portland, OR
QUOTE (Junior @ Aug 14, 2004 - 4:34 AM)
I was mainly thinking about using ply wood for like a center basis to just put the sub woofer in and that part would be flat and then on the sides would be where the mold comes in. Now also, for putting in speakers and what not, is it okay to just screw the speakers right into the fiberglass or do I need a wooden circular frame built in under the glass to drill into???
post Aug 17, 2004 - 4:42 PM
gtcelica94
Joined Apr 4, '04
QUOTE (DamDirtyApes @ Aug 16, 2004 - 2:41 PM)
best site , first learned how to fiberglass from this site
post Aug 17, 2004 - 4:52 PM
acenova
Joined Dec 21, '03
From Portland, OR
Took a quick overview, that site is awesome man!!! Thanks a lot. that makes me wanna start today! biggrin.gif Bad ass, thanks man.
Lo-Fi Version Time is now: August 25th, 2026 - 2:09 PM
