2 Pages V  < 1 2
> GT4 Tranny
post Mar 4, 2003 - 1:01 AM
Mage
You guys are absolute morons considering you made those insulting posts without even realizing what the issue was. A guy was asking for advice on what tranny to use. I told him, while clarifying that the suggestion to do an AWD swap right away isn't feasible (the guy doesn't sound like he wants to cut up his car at any rate). I don't give a **** if I sound like your "ex gf," all I've spoken here is common sense, apparently a foreign concept to you. This THREAD wasn't about an awd conversion, it was about using the st205 tranny in a 3sgte swap which is NOT POSSIBLE WITH FWD.
Unless you mod the engine to about 300+ hp, I think the consensus was that the GT tranny would be 'fine.' That doesn't help much, but when one guy dyno'd at 500 HP with his 3sgte-swapped celica, everybody was mentioning that he should have a couple extra trannys standing by. Ask the people who've done the swap (there are quite a few actually). You can use the MR2 pressure plate.
post Mar 4, 2003 - 1:09 AM
Guest_Matthew_*
yea if he doesn't plan on building up his 3s-gte then he should definitely use the gt tranny and keep the car FWD. But if he is planning on building up his engine then he should take the extra time and money to do the AWD conversion.
There, I agreed with you.
Also just one more thing. When you do the AWD conversion, you don't really cut up your car. You DO do some cutting of your car. But it sounds like (not just you either) people make it sound worse than it actually is.
post Mar 4, 2003 - 10:29 AM
rlan214
Joined Dec 27, '02
From Sleep in Warren chill in clinton twp, works/school in detroit
to answer ure tranny q here go to c net
post Mar 4, 2003 - 1:14 PM
Mage, thanks you answered my question.
post Mar 7, 2003 - 7:36 AM
Neipas09
Joined Sep 5, '02
From Phoenix, AZ
QUOTE (Mage @ Mar 3, 2003 - 11:01 PM)
.....This THREAD wasn't about an awd conversion, it was about using the st205 tranny in a 3sgte swap which is NOT POSSIBLE WITH FWD.
Isn't the AWD actually just a FWD with a rear differental???
2 Pages V  < 1 2
Lo-Fi Version Time is now: May 18th, 2026 - 4:51 PM
