Aug 16, 2004 - 11:53 AM
Right now I'm so depressed about my car.
A couple weeks ago I found out that in addition to problems with my clutch's hydraulic system and my tranny, I also have some sort of a problem with the valves on the head of my 4A-GE. I hope it's valve lash and can be fixed fairly easily, but I talked to a couple people and they told me that I may need new valves, which would cost more than another head from a AE101 4A-GE. So I dunno what to do about this yet. It can be done after the tranny and hydraulic system is fixed though(once I pay off the additional $600 of debt that I'm in), as it's just a loud clicking noise when the engine is at idle. So things weren't too bad until yesterday. Yesterday I decided to install a VVT light in one of my vents so that it could act as a shift light sort of thing. I installed it, only to find out that my car isn't hitting VVT, and never has been, as it's always felt the same as it does now! So I figured maybe it was the speed sensor, since I've been hitting fuel cut at 7,600 RPM or so lately, so I pulled out the ECU to test the pin for the speed sensor. Upon pulling out the ECU, I found that NONE of the wires going into the ECU connectors match what they should be from the pinouts, so testing wires and stuff is going to be a nightmare. So I just don't know what to do. My options are: 1. Fix the car's tranny and hydraulic system and sell it to someone locally. Sell all the parts that I've got sitting around(TRD Curren wing, 5 subs, 1 amp, Lotek pillar pod, oil temp/pressure gauges, piping/connectors for a CAI, front '94-'95 extensions, DG side tower bars, fiberglass 10" sub enclosure, window roll-up module, etc.) Then buy an Infiniti G20. 2. Fix the car's four major engine/drivetrain problems, repaint it, and keep it. This route involves spending thousands of dollars, and most likely taking the car up to a shop in Seattle where they'll charge me lots of money to completely re-do the wiring harness, buying tons of parts, etc. I just don't know...I need something to drive though, and every day it's another problem with the Celica. -------------------- New Toyota project coming soon...
Coomer What To Do? Aug 16, 2004 - 11:53 AM
dstrbcelica as much as i hate to say it coomer, with all your ... Aug 16, 2004 - 12:36 PM
spunky393 mmmmmmmmmmmmmmm................................ G... Aug 16, 2004 - 1:17 PM
Supersprynt Depends on how much you want this car to work out.... Aug 16, 2004 - 1:19 PM
LatinKraze Sounds like a lot of work. Go for the G20 Bro. Aug 16, 2004 - 1:23 PM
shid So who wired up your ECU? Aug 16, 2004 - 1:24 PM
jgreening I agree with Super. Its a matter of how much crap... Aug 16, 2004 - 1:27 PM
ghostdog QUOTE (Supersprynt @ Aug 16, 2004 - 2:19 PM) Depen... Aug 16, 2004 - 1:28 PM
urbandork i agree if ur heart is losing faith in the car the... Aug 16, 2004 - 1:32 PM
Coomer QUOTE (shid @ Aug 16, 2004 - 11:24 AM) So who wire... Aug 16, 2004 - 1:35 PM
Jdog1385 its tough. i have the same problem. I want to do... Aug 16, 2004 - 1:36 PM
Coomer QUOTE (jgreening @ Aug 16, 2004 - 11:27 AM) How ab... Aug 16, 2004 - 1:42 PM
boosted_K2 keep the celi, take it to a reliable shop, get the... Aug 16, 2004 - 1:56 PM
shid Drive it down to LA for a months vacation; everyon... Aug 16, 2004 - 2:24 PM
Coomer There may be hope...I took it to my mechanic on my... Aug 16, 2004 - 3:43 PM
sphinx QUOTE (shid @ Aug 16, 2004 - 12:24 PM) Drive it do... Aug 16, 2004 - 3:57 PM
o8poa8o you could just spend the money to get it fixed the... Aug 16, 2004 - 3:59 PM
Coomer QUOTE (sphinx @ Aug 16, 2004 - 1:57 PM) i'll f... Aug 16, 2004 - 4:03 PM
o8poa8o i read over my post after i posted it and thought ... Aug 16, 2004 - 4:16 PM
Supersprynt Option 3 isnt an option since it has the word HATC... Aug 16, 2004 - 4:48 PM
shid QUOTE (Supersprynt @ Aug 16, 2004 - 9:48 PM) Optio... Aug 16, 2004 - 4:52 PM
o8poa8o when did anyone say anything about a sentra? but s... Aug 16, 2004 - 4:54 PM
Coomer QUOTE (Supersprynt @ Aug 16, 2004 - 2:48 PM) Optio... Aug 16, 2004 - 4:56 PM
o8poa8o just ingore my post im goin to far off topic Aug 16, 2004 - 4:57 PM
Supersprynt QUOTE (Coomer @ Aug 16, 2004 - 5:56 PM) QUOTE (Sup... Aug 16, 2004 - 5:30 PM
sphinx QUOTE (Coomer @ Aug 16, 2004 - 2:56 PM) QUOTE (Sup... Aug 16, 2004 - 5:30 PM
sphinx QUOTE (Supersprynt @ Aug 16, 2004 - 3:30 PM)
Me t... Aug 16, 2004 - 5:31 PM
Coomer QUOTE (Supersprynt @ Aug 16, 2004 - 3:30 PM) QUOTE... Aug 16, 2004 - 5:40 PM
Supersprynt QUOTE (Coomer @ Aug 16, 2004 - 6:40 PM) QUOTE (Sup... Aug 16, 2004 - 5:41 PM
Fingaz ^^^^likes a lot Aug 16, 2004 - 5:42 PM
o8poa8o so you've never used or hit VVTI? whoa then yo... Aug 16, 2004 - 5:48 PM
Pali_playa yea, ur gonna love ur car alot more when u hit VVT... Aug 16, 2004 - 7:17 PM
lagos coomer...its time to become a mechanic like the re... Aug 16, 2004 - 7:32 PM
saleeka QUOTE (Supersprynt @ Aug 16, 2004 - 9:48 PM) Optio... Aug 17, 2004 - 2:10 AM
97sccelica QUOTE (sphinx @ Aug 16, 2004 - 12:57 PM) QUOTE (sh... Aug 17, 2004 - 2:33 AM
Magic You should try to find a reliable engineer for the... Aug 17, 2004 - 4:06 AM
bufferdan You probably just need a new master or slave cylin... Aug 17, 2004 - 8:16 AM
DamDirtyApes sell it to someone who appreciates what uv done to... Aug 17, 2004 - 8:29 AM
Coomer So the new fuse didn't help...I still can... Aug 18, 2004 - 1:08 AM
macavely go with number one.. save up and get a second car.... Aug 18, 2004 - 1:24 AM
Kwanza26 I too will offer the services of our shop (actual ... Aug 18, 2004 - 1:39 AM
hioctane time for an mr2 turbo
Come to the dark side!... Aug 18, 2004 - 1:39 AM
97sccelica QUOTE (Coomer @ Aug 17, 2004 - 10:08 PM) So the ne... Aug 18, 2004 - 2:21 AM
95STHATCH Defective mechanic is more like it. Aug 18, 2004 - 5:12 AM
Coomer QUOTE (Kwanza26 @ Aug 17, 2004 - 11:39 PM) I too w... Aug 18, 2004 - 1:45 PM
Coomer Augh! More problems!
A couple days ago I... Aug 21, 2004 - 3:12 AM
tufy buy it and get a better 6 gen. celica. swap an gt ... Aug 21, 2004 - 3:44 AM
fastgt coom id say to just just get the wiring re-done , ... Aug 21, 2004 - 4:38 AM
Digndoug Get a bimmer .. hehehehehe... Aug 21, 2004 - 11:33 AM
Anub1s Man coom I really do sympathize here. My old S10 t... Aug 21, 2004 - 12:38 PM
Jeremy1210 QUOTE man. You might want to take the car to a pro... Aug 21, 2004 - 1:34 PM
Coomer OMG!
My mechanic is straight-up retarded... Aug 21, 2004 - 10:08 PM
shid Coom, so you're hitting VVT now? Aug 21, 2004 - 10:25 PM
YellowTwo QUOTE (shid @ Aug 21, 2004 - 8:25 PM) Coom, so you... Aug 22, 2004 - 1:42 AM
macavely Coomer have you checked the harness clips.. .. th... Aug 22, 2004 - 3:13 PM
Coomer QUOTE (macavely @ Aug 22, 2004 - 1:13 PM) Coomer h... Aug 22, 2004 - 3:21 PM
macavely then you shoold take a weekend with some friends ... Aug 22, 2004 - 3:27 PM
Coomer QUOTE (macavely @ Aug 22, 2004 - 1:27 PM) then you... Aug 22, 2004 - 3:41 PM
97Celica You should get it off of the CRX that Itchy and I ... Aug 22, 2004 - 3:46 PM
Coomer Woo Hoo! I just found out that the clicking I... Aug 25, 2004 - 12:01 AM
sphinx I helped.
WOOT Aug 25, 2004 - 12:35 AM
funnyboy117 GO COOMER!! Aug 25, 2004 - 1:40 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 29th, 2026 - 10:08 AM |
