Aug 18, 2004 - 12:07 AM
Enthusiast ![]() Joined Aug 13, '03 Currently Offline Reputation: 0 (0%) |
my friend just got some wing put on his car and im wonderin how can it be cover..usein what...i heard of bondo but i was wonderin if anybody know anything else easier .....any help be thankful....thanks b4 head of time
Aug 18, 2004 - 7:09 AM
Enthusiast ![]() ![]() Joined Nov 29, '03 From Hampton, VA Currently Offline Reputation: 0 (0%) |
Cover what hole? If you took off the stock spoiler there should be three on both sides and one (or two) in the middle. Closing it off right involves welding the holes shut with a mig welder, using body filler, and repainting that area of the car.
This post has been edited by flipside97LTD: Aug 18, 2004 - 7:10 AM -------------------- ![]() |
Aug 18, 2004 - 10:27 AM
Enthusiast ![]() ![]() ![]() Joined Apr 4, '04 From New York Currently Offline Reputation: 0 (0%) |
go buy some metal tape, use a peice to cover the whole area, push the tape in the hole after you layed it flat over the hole. get some fberglass.dyna-glass or what evers, sand 80 grit, put some body filler over it, sand 80 grit, then some spot putty sand down with 220 grit, call it a day
Aug 18, 2004 - 10:58 AM
now where do i get alll of these stuff from..pepboys?
Aug 18, 2004 - 10:59 AM
can u guys giv me the name of the product soo i can get it...thanks
Aug 18, 2004 - 2:48 PM
you can get the tape from pepboys, look in the phone book for body shop supplies and ask them if they carry body fillers and fiberglass filers. Evercoat is a good name.
filler site this is a good site to buy stuf from , i get my supplies from them |
Aug 18, 2004 - 7:22 PM
kool just wat i needed...thanks a bunch
Aug 18, 2004 - 10:25 PM
duck tape. they have lots of different colors also
Aug 18, 2004 - 10:52 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 13, '03 From California Currently Offline Reputation: 2 (100%) |
gum might work????....haha im no help
id say (if you were me) take it to a body shop -------------------- 2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3 gone but not forgotten 2008 Space Grey BMW Z4 ///M 2009 Black Honda Civic LX Coupe 2006 Magnetic Black Nissan 350Z 2007 Crimson Red BMW 335i Coupe |
Aug 19, 2004 - 7:04 AM
![]() Enthusiast ![]() ![]() Joined Jan 22, '04 From WA, Australia Currently Offline Reputation: 1 (100%) |
if you took it to a body shop, how much would you be looking at? and also if using the method/s above, is it very noticable that there were holes there in the first place?
Aug 19, 2004 - 9:44 AM
i call around and even driv to some bodyshop..some told me 200 and some rols 250...i only have 6 holes to fill in...why so much ....im usein tape rite now to cover the holes up....after removin the stock spoiler..yea the was holes already..haha
This post has been edited by VietCelicaGt: Aug 19, 2004 - 9:47 AM |
Aug 19, 2004 - 4:57 PM
Well I just finished welding up my holes. I took off the stock spoiler and am putting on the hiro wing. The holes that didn't match, I welded up and it looks great. I still have to paint the car but you can't see the holes anymore. This is most likely what a bodyshop is going to do.
Aug 19, 2004 - 5:08 PM
To do that: use a surface grinder and grind to bare metal all around the holes you'll be welding (about an inch or so from the hole). Now grind to the bare metal somewhere else in an unnoticable place, this is where you'll connect the charge clamp from the welder. Now weld the holes shut. When you've got them welded up, use the surface grinder to grind the weld down flush with the car. The heat from the welding is going to cause the metal around the welds to heat up and it's going to sink down a little. That why you need to use body filler. Fill over the welds and smooth out the sinkage until it looks like original. Then repaint it.
Aug 19, 2004 - 5:14 PM
that looks good, how easy is it to weld.
i found a pic if you still want to do it the fiberglass way
Aug 19, 2004 - 5:20 PM
omg that a big hole....but goood pic ...it be a goood guide...i will use the pic to guide me to cover or fill the hole
Aug 19, 2004 - 5:24 PM
Well it seems both ways will work. How durable is that tape? The only problem I see is that if that tape sunk in, the filler wouldn't be strong enough to hold the shape.
Aug 19, 2004 - 5:43 PM
the tape is only there to make a mold. look at 8, its fiberglass,9 is the filler over the glass.
Aug 19, 2004 - 5:57 PM
hwo about just finding some type of rubbler stopper to put in there. if you do it the same color as your car, it wont look that bad, and you can reinstall the wing, if you choose to go back to that look later.
Aug 19, 2004 - 6:27 PM
Well it depends dude, see if he's gonna be putting in a new wing, rubber stoppers might get in the way. I guess it just depends. Beautiful car by the way lagos.
This post has been edited by flipside97LTD: Aug 19, 2004 - 6:28 PM -------------------- ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 12:55 PM |
