> What can be done to beef up the stock GT tranny?, already ran a search
post Aug 18, 2004 - 7:37 AM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
This has probably been discussed before, but I couldn't find what I needed when I ran a search. I was wondering if you guys could tell me what is needed to beef up the GT stock tranny, so it'll handle the 2nd gen 3sgte better. Orrr......do I really need to beef it up at all??
post Aug 18, 2004 - 7:48 AM
you dont need to do anything to the tranny. it handles the power of the 3sgte just fine.
if anything, try not to abuse your tranny in the meantime, refill it will fresh oil, and just take car of it.
post Aug 18, 2004 - 9:48 AM
jgreening
Joined Jan 17, '04
From Illinois
I am not an expert but here is a list of guys that will tell you differently:
Sphinx (x2), Supersprnyt, Kuya1284, Dirty, Keoni (celica.net), rm2932, there's another guy from Hawaii (I can't remember his name), as well as others I do not know.
These guys either have personal experience or know people that have personal experience with the GT tranny and the 3sgte and they will all tell you that the tranny is less than ideal for the swap. Some will have much less kind words. For what it is worth, I did not even consider keeping the GT tranny with my swap after all the adverse posts I read. (see buying and selling forum for real good deal on GT tranny...smiles)
As for your question, I ran across a post on celica.net that said a tranny could be "shot pinged"? or something similar to that to strengthen it. I have no idea what that means or even if its true. Perhaps some experts here can help us out. *cough* Kwanza *cough*
post Aug 18, 2004 - 10:08 AM
shid
Joined Jan 8, '04
From LA
QUOTE (jgreening @ Aug 18, 2004 - 2:48 PM)
Jay, keep in mind a lot of these people did stuff to the engine; and as such it was putting a lot more power to the wheels. I know Sphinx had a boost controller (I think?) which opens up a lot of hp right off the bat.
post Aug 18, 2004 - 10:38 AM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
Hands down, if you plan on just swaping a 3sgte and that's it. Then you CAN use a GT tranny. It will hold up, but you cant boost higher than 8psi. If that's all the power you're going for, then OK.
But if you're Power Crazy like me and the power you have is never enough, then DON'T get the GT tranny. It will die on you. I have trashed 2 GT tranny's, and now i'm going with the E-series.
Shid, I do have a Boost Controller (APEXi) and most of the time, I have it set at 12psi. I rarely have it at 8psi. But like I said, i'm power crazy. And hopefully by the end of the year, a Ball Bearing GT3040 turbo will be installed, and I sure as hell will not be able to play with that bad boy with a GT tranny.
Simple swap and nothing else = GT tranny will be OK.
Swap with future upgrades = GT tranny will not do so well.
You could add a LSD to the tranny, (i think TRD is the only one who makes one for the s54) but that will cost you arround $800- $900 and i'm not sure how well it will still hold up.
This post has been edited by sphinx: Aug 18, 2004 - 10:43 AM
post Aug 18, 2004 - 10:40 AM
I dont like the GT tranny because of its short gearing (although ideal for quick acceleration) its not good for top end and the tranny runs outta room to go forward pretty quickly.
Not to mention you cant go hard on the tranny, i'm constantly worrying about it, it just takes away from the enjoyment of driving the 3s.
And once you get the feel of power you want more, i'm pushing 10-12psi regularly which idk could be around 250 at the crank on the JDM ecu.
You can get by with the transmission, DEFINATELY get at least a stage 1, stage 2 would be better on the 5s disc. If you have the money, look for at least a E153 MR2 tranny and if u luck out and find an LSD version, it will be more expensive but the LSD helps.
post Aug 18, 2004 - 10:47 AM
sphinx
Joined Apr 10, '03
There is a JDM mr2 Turbo tranny for sale on Ebay right now.
TOYOTA MR2 3SGTE Turbo Manual Transmission JDM MR-2
post Aug 18, 2004 - 6:38 PM
hmm...a lot of these tranny problems could be do to the fact that some of you guys have over 100,000miles on those trannys. no one knows how often the oil was changed or how the car was drivin from day one.
for my swap, i used my 5sfe tranny, becasue it barely had 50,000 miles on it. id rather have that, then some junk yard trans with unknown milage or history.
my future plans are, more power at about about 14psi of boost. i am confident that it will hold. ive seen quite a few people running the gt trans with no problems at those boost levels. (calyton to name one)
post Aug 18, 2004 - 8:51 PM
sphinx
Joined Apr 10, '03
Well, I don't want to be an ass, but if and WHEN your tranny goes out on you, I'll be the first to say "I told you so"
This post has been edited by sphinx: Aug 18, 2004 - 8:51 PM
post Aug 18, 2004 - 8:52 PM
shid
Joined Jan 8, '04
From LA
Lagos, thats things gonna crap out before 14 psi of boost... a brand new GT tranny would. I mean, Sphinx ran through 2 of them at 12 psi.
post Aug 18, 2004 - 8:57 PM
sphinx
Joined Apr 10, '03
who knows, it might also be that I run my motor hard. I run it hard enought to enjoy it. But if you are easy on the peddle, then it might work.
I mean, who really knows, right?
post Aug 18, 2004 - 9:04 PM
shid
Joined Jan 8, '04
From LA
QUOTE (sphinx @ Aug 19, 2004 - 1:57 AM)
Where's the damn fun in that?
::driving the vert too hard and getting body flex::
post Aug 18, 2004 - 9:18 PM
I once saw a thread on some MR2 forums where some guy was pushing around 450 whp in his 3S-GTE-swapped sixth gen. Celica with his stock 5S-FE tranny, and he said it was holding up fine. Maybe you've just got bad luck like me sphinx. wink.gif
post Aug 18, 2004 - 9:48 PM
sphinx
Joined Apr 10, '03
I remeber that thread coomer, and if i'm not mistaken, he had a TRD LSD installed. biggrin.gif
post Aug 18, 2004 - 10:54 PM
QUOTE (sphinx @ Aug 18, 2004 - 7:48 PM)
post Aug 18, 2004 - 11:16 PM
yeah....honestly...if you beat on it,t will die...even the mr2 tranny.
post Aug 19, 2004 - 12:06 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (sphinx @ Aug 18, 2004 - 6:48 PM)
LSD would only make the tranny break sooner tho
more traction means you can break things more easily.
thats the only downfall of AWD imo, along with top end, in some peoples' eyes, but i for one dont care for 100+mph
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Aug 19, 2004 - 9:42 AM
Anub1s
Joined Nov 27, '03
wow you don't live on the dangerous side at all tongue.gif I love going faster than 100 (where it is safe to and out of the way of course) But I agree with the statement about LSD its just more wear and tear on a Tranny that wasn't designed originally to handle all of that power and distribute it a different way. That just makes for bad things.... I've got a freind who put an integra LSD into his prelude tranny (he paid a lot for the custom work on that) and I will see how that works out for him. I will base my decisions of getting an LSD off of that.
post Aug 19, 2004 - 10:38 AM
sphinx
Joined Apr 10, '03
QUOTE (Anub1s @ Aug 19, 2004 - 7:42 AM)
I hope you're talking about the S54 tranny and not the MR2 .
Lo-Fi Version Time is now: June 25th, 2026 - 3:28 PM
