Mar 2, 2003 - 9:31 AM
Enthusiast Joined Mar 2, '03 From U.K Currently Offline Reputation: 0 (0%) |
Can anyone help me. I want to remove the factory fitted sony double din unit in my celica and replace it with a single unit. I dont know how to get the thing out, any advice would be appreciated
Mar 2, 2003 - 10:45 AM
Enthusiast ![]() ![]() Joined Dec 17, '02 From UK Currently Offline Reputation: 0 (0%) |
Ok, what you have to do first is remove the plastic surround from the base of the gear stick - it just un-clips. You can't remove it completely though, just loose.
Then you should be able to see the base of the centre console trim, there are 2 screws that you need to undo. Now carefully pull the centre console trim panel forward . It is just clipped in place. The vents come off with the panel but stay attached to it. Watch out for the hazard light and clock which will need unplugging from the console when it is half way out. With the trim out you will now see the 4? bolts that hold the stereo in place. Good luck. This post has been edited by Tony-94: Mar 2, 2003 - 10:46 AM -------------------- Facelift bumper-foglights-clear indicators, clear side repeaters, 16in O.Z alloys, stainless steel grill. JDM facelift tail lights. clear sidelights. Retro-fit A/C conversion. APEX performance springs. Remus exhaust. K&N performance filter. KYB excel G shocks.
Hyundai coupe Mk 3 (US Tiburon) leather seats. Gen 7 s/wheel. SR black vinyl door cards. Late spec spoiler-less tailgate with 3rd brake light. |
Mar 2, 2003 - 2:02 PM
Thanks, i will give it a go, is it easy to do or do you think i will be better off getting the toyota garage to do it for me
Mar 2, 2003 - 7:20 PM
Removing the trim panel and taking the old stereo out is easy. I think the hardest part will be fitting the new radio because the gen 6 radio doesn't conform exactly to the normal DIN fitting used by almost every car. It wont slot in as easy as the Toyoya unit did and might need to adapt the new stereo's cage or mounting brackets. It is possible though.
(BTW You don't need to unplug the hazard or clock from the panel but it gives you more space to work in.) -------------------- Facelift bumper-foglights-clear indicators, clear side repeaters, 16in O.Z alloys, stainless steel grill. JDM facelift tail lights. clear sidelights. Retro-fit A/C conversion. APEX performance springs. Remus exhaust. K&N performance filter. KYB excel G shocks.
Mar 3, 2003 - 12:13 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
True enough. Also, when you get the regular DIN unit in place, it fits beautifully.
Mar 3, 2003 - 12:38 PM
![]() Enthusiast ![]() Joined Dec 22, '02 From Missouri Currently Offline Reputation: 0 (0%) |
gdmit...my computer is retarted! sorry for the double posting!
This post has been edited by ashleyzredcelica: Mar 3, 2003 - 12:40 PM |
Mar 3, 2003 - 12:39 PM
Yeah after its all done its looks awesome!
click me! |
Mar 3, 2003 - 9:09 PM
good link
This post has been edited by igotta5S-FEturbo: Mar 3, 2003 - 9:12 PM |
Mar 3, 2003 - 9:10 PM
anybody have a write up?
This post has been edited by igotta5S-FEturbo: Mar 3, 2003 - 9:13 PM |
Mar 4, 2003 - 2:33 PM
It's strange, because when I tried to fit a single din head unit the radio was too wide to fit through the center console panel. It wouldn't fit 'underneath' the console panel properly either and just looked really untidy
Mar 8, 2003 - 12:11 PM
O.k just tried installing my h/u and it was too wide to fit into the dash, any ideas or examples of what to do now
| Lo-Fi Version | Time is now: May 17th, 2026 - 4:56 AM |
