> need a diagnosis, clunking sound
post Aug 21, 2004 - 12:43 PM
ghostdog
From ny to philly
recently my car has started making a strange clunking sound. this started after I put it up on jackstands to replace some of the screws in the plastic splashguard. now I don't understand how this could start a problem such as this but I thought I would mention it anyway.
okay so the problem is as follows:
starting up the car when I put the clutch in and turn the key it makes a loud clunk. when I accelerate suddenly, either when changing gears or just stab at the throttle this same clunk can be heard. the sound does not happen when the car is not in gear and happens in any rpm. my friend commented that it sounds like something is hitting the firewall, yes it almost sounds like that and can be quite loud if I jerk the throttle back and forth a couple times.
whoever tells me whats going on gets a cookie
thanks.
post Aug 21, 2004 - 1:01 PM
Gooo, motor mounts?
post Aug 21, 2004 - 1:14 PM
ghostdog
From ny to philly
QUOTE (Supersprynt @ Aug 21, 2004 - 2:01 PM)
Gooo, motor mounts?
I was thinking that but I heard that motor mounts shouldn't be a problem above 1500-2000 rpms, and this is all through the rpm range. also the sound on startup? does that happen with motor mounts?
post Aug 21, 2004 - 1:22 PM
Well i figure the engine shakes alot when you first start it up, and if you dont have good mounts its going to shake alot hitting any lilttle bump.
Im just throwing out ideas.
post Aug 21, 2004 - 3:10 PM
spunky393
Joined Apr 22, '04
From illinois
My car does this too every other day. Never on start up might i add though. I would like to know what it is too, because i really bothers me, it sounds terrible.
post Aug 21, 2004 - 5:35 PM
Rjb23
Joined Feb 8, '04
From KY
Uh you left the screwdriver in the engine and its clunking around?
post Aug 21, 2004 - 5:53 PM
shid
Joined Jan 8, '04
From LA
QUOTE (Rjb23 @ Aug 21, 2004 - 10:35 PM)
I'm gonna second this smile.gif it's happ to the best of us
post Aug 21, 2004 - 11:23 PM
ghostdog
From ny to philly
QUOTE (shid @ Aug 21, 2004 - 6:53 PM)
uhh no. I actually checked for that already. I've learned never to underestimate my own stupidity wink.gif
any other ideas/things to check?
post Aug 21, 2004 - 11:27 PM
clunk almost always = bad axeles
post Aug 22, 2004 - 12:40 AM
spunky393
Joined Apr 22, '04
From illinois
how do we go about checking for "bad" axels?
post Aug 22, 2004 - 1:20 AM
shid
Joined Jan 8, '04
From LA
The same way you go checking for bad axis powers. nyuk nyuk nyuk
post Aug 22, 2004 - 9:01 AM
get under your car a look at the axel boots. see if the boot has any rips in it, or of you see that any of the grease is starting to leak out of it. also grab the axel arm, and push and pull on it. if it feels like its moving around too much, then thats probably the bad one.
This post has been edited by lagos: Aug 22, 2004 - 9:03 AM
post Aug 22, 2004 - 10:43 AM
AgtX
Joined Aug 6, '04
had this in a previous car i had, clunked like that, found out what it was when the clutch pedal suddely went flat to the floor and heard lots of grinding, gearbox mounting ripped itself away from the box and left a hole in the top of the gearbox and the engine hanging down at one end. It was a loose gearbox mounting.
Probably not the same thing but it reminded me a lot of that. Just get it checked at Toyota dealer, it wont cost you anything for them to look, putting it on a lift or better, over a pit would help cause you could make it clunk while theyre underneith.
Lo-Fi Version Time is now: July 10th, 2026 - 9:33 AM
