Mar 3, 2003 - 3:09 PM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) |
Hello guys, I've a 94 7AFE manual transmission and I need the ECU wiring diagram of my car or just to know if 7AFE and 4AFE pins are the same.
If none available I just need to know which is the ECU pin for the O2 sensor SIGNAL. Thanks Edoardo |
Mar 7, 2003 - 6:28 PM
![]() Enthusiast ![]() ![]() Joined Oct 25, '02 From London- England Currently Offline Reputation: 0 (0%) |
Eduardo,
Sometimes it's worth checkin the older pages of the forum, you usually find that your question has been raised before, here's the link I posted last time http://www.geocities.com/MotorCity/Pit/997...ct/Pinouts.html You can check the oxygen/Lambda sensor voltage at the DLC1 (data link box) in the engine bay (Voltage between pin TE1 and E1/Earth), Jon |
Mar 7, 2003 - 9:48 PM
I have already seen all posts, your too, but in the link that u posted there isn't the 7AFE ecu and I don't think that it could be similar to 5SFE due to the different engine family (A vs S)
Maybe it could be similar to 4AFE ECU but who can confirm this?!?!?! Thanks Edoardo |
Mar 8, 2003 - 6:45 PM
Ok, you've forced me into pulling my finger out
The 7AFE (1.8ST) has 2 oxy sensors, main one is hooked up to the Data link connector on the left rear of engine bay,the same link runs of to the ECU pin 6, pin 5 being the second sub oxy sensor, both wires are coloured white, Jon |
Mar 8, 2003 - 9:10 PM
But....you've a full diagram of my ECU!?!?!!?! please send it to me, also through PM....I need it also to wire my SAFC2
Mar 9, 2003 - 5:18 AM
the image I have of the ECU is held in a format specific to
an exclusive program and so isn't capable of being converted to another pic format. I'll have to print it up and image capture it and email it to you sometime Monday, Jon |
Mar 9, 2003 - 7:11 AM
Thanks!!!!!!!!!!!! you save me!!!!!!!!!!!!!!!!!!!!!!!!!
my email is edoardox@fastwebnet.it thanks again!!! Edo17982 PS:my model is 7afe manual transmission with AC. |
Mar 9, 2003 - 10:23 AM
Ed,
your in luck, I've got a third party software image capture program which will convert the diagram "on screen" to a BMP format. Will post the files to your email as attatchments. Files are about 2Mb each, top and bottom clips of the ECU pinouts. You'll have to zoom the pictures to get a clearer view of the small print. Post back on this forum if you get the files OK, Jon |
Mar 9, 2003 - 1:05 PM
Ok,you're my saver!! thx
| Lo-Fi Version | Time is now: May 18th, 2026 - 4:18 PM |
