Aug 25, 2004 - 11:46 AM
Enthusiast ![]() Joined Aug 20, '04 From VA Currently Offline Reputation: 0 (0%) |
Hey i have a 96 ST and i was wondering if they make cold air intake for that. If so where can i get a good one. And if not where can i get a good short ram intake. Thanks
Aug 25, 2004 - 11:50 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 22, '03 Currently Offline Reputation: 0 (0%) |
CAI
Short Ram Dragon Intake Make Your Own Hope this helps This post has been edited by LatinKraze: Aug 25, 2004 - 11:51 AM |
Aug 25, 2004 - 11:57 AM
Hey i found this cold air intake what do you think?
http://www.autopartsauthority.com/cold_air...njen~parts.html For those who have cold air and short ram, which is better? And are there any problems with either. thanks |
Aug 25, 2004 - 12:06 PM
The S-shaped injen intake looks good. It's not a cold air intake tho. If you want to dress up your engine bay, buy it. If your just going for HP gains, wich will not be much, get a hi-flow air filter from TRD. It's cheaper and it gets the same gains as the aftermarket intake.
This post has been edited by LatinKraze: Aug 25, 2004 - 12:08 PM |
Aug 25, 2004 - 2:37 PM
How is the injen not a cold air intake?
Aug 25, 2004 - 2:49 PM
Click on the pictures and it will show what each is.
EDIT: CAI is a tube with a filter at the end under your car. Like the first link I posted. An intake has the filter located inside you engine bay, by the battery. This post has been edited by LatinKraze: Aug 25, 2004 - 2:51 PM |
Aug 25, 2004 - 2:53 PM
So what do you suggest the CAI that you linked me, the short ram that you linked me, the weapon R, or the Injen?
Aug 25, 2004 - 3:01 PM
Its your call dude. They both have ups and downs.
The CAI: Better Hp gains, but can cause a problem when it rains (installing a breather helps). The Injen Intake: Less Hp gains, no risk of hydrolock, has the same gain as a drop-in hi-flow air filter by TRD (which is cheaper). |
Aug 25, 2004 - 3:08 PM
Id like to go with the CAI for better gains but im worried about hydrolock. What do i need to intall a breather i dont know much about that. And are there any other remedies to prevent hydrolock w/ CAI. thanks man
Aug 25, 2004 - 3:20 PM
Unless the filter of your CAI gets completely submerged(and you'd have to drive through a pretty huge puddle to do so), you don't have to worry about hydrolock. Installing a breather is easy, and basically entails cutting the pipe closer to the intake manifold, and inserting a breather, or bypass valve into it.
Aug 25, 2004 - 6:24 PM
How would i know how much of the pipe i would need to cut in order for the bypass vavle to fit? And where can i buy one? thanks for the help
Aug 25, 2004 - 6:30 PM
Some bypass valves only need a hole drilled on the side to fit. I'll find a pic somewhere.
Aug 25, 2004 - 6:33 PM
Here's one that coomer is talking about.
Aug 25, 2004 - 10:38 PM
So i would have to cut the pipe at the intake manifold to make room for this small piece?
| Lo-Fi Version | Time is now: August 2nd, 2026 - 4:27 PM |
