> track day at cayuga race way Toronto
post Aug 28, 2004 - 11:01 PM
celicaspeed
Joined Aug 22, '04
From kitchener,Ontario
I went to the track with my buddies and our girls and I watched some cars racing!I saw a cavalier run 17's biggrin.gif and I saw a dodge neon srt run 14's constant.Than this guy from Toronto I met was kicking everybodys ass all day long he had the same car, body kit, and he was running a 1st gen 3sgte motor stock with the fmic and running at 20psi boost on a ct26 stock turbo with a electronic boost controler.And he ran 13.1 sec.Et's were 2.2 steady all day long! biggrin.gif And I have more done to mine than his so Im woundering what my car will run in the 1/4 mile?Can somebody go to my topic title 1st gen swap into a 94 gts and read my mods and tell me a rough idea of what I should be running?
This post has been edited by celicaspeed: Aug 28, 2004 - 11:03 PM
post Aug 28, 2004 - 11:03 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
CT26 can't boost 20psi...
post Aug 28, 2004 - 11:06 PM
celicaspeed
Joined Aug 22, '04
I didnt think so either untill I saw it my self!His boost controler ads more pressure to the waste gate spring so it wont open and his turbo just keeps building boost untill his boost controller sets it at 20 before it pops off!
post Aug 28, 2004 - 11:12 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (celicaspeed @ Aug 29, 2004 - 4:06 AM)
are you sure dude? 20psi is a lot... I just don't see the ct26 doing that without nearly melting... not to mention the stock motor will blow up cause the pistons can't take more than 15 or so psi...
post Aug 28, 2004 - 11:25 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
dude i saw a forum and dyno sheets where some dumbass honda guy in a intergra ran 27 psi on stock internals. and all he doen since is 12psi. there are dumb people out there.
ill find the article
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Aug 28, 2004 - 11:32 PM
celicaspeed
Joined Aug 22, '04
The motor is good for 20psi boost as long as you dont do it often!!As long as you can keep the waste gate closed your turbo will keep building boost!It's not an everyday thing just at the track.I think he keeps it at 12psi usually.
post Aug 29, 2004 - 11:17 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (celicaspeed @ Aug 28, 2004 - 8:32 PM)
20psi is stupid on a stock ct26 turbo
the air charge would be so hot that detonation would be unavoidable
and his boost controller probably works the same as every other boost controler, nothing special about it, just that the guy is running it way too hard.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Aug 30, 2004 - 12:49 PM
celicaspeed
Joined Aug 22, '04
It all depends on your map sensors.When you get your car on a dyno they check your peak horse power and they check were your car starts to loose power.then at the max peak horse they check your fuel map and depending on your maps you might still be able to give it more juice and some times you loose power.It also depends on your compressor wheel.Now not all boost controllers are created equal!!! So you can throw that theory right out the window.As long as your car keeps building boost with steady fuel there will be no detonation because your car wont have the chance to go lean,as long as everything is done right!
post Aug 30, 2004 - 1:54 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (celicaspeed @ Aug 30, 2004 - 5:49 PM)
Not when you refer to stock components...
post Aug 31, 2004 - 1:24 AM
celicaspeed
Joined Aug 22, '04
the whole point is hes done it and he has done it more than once so it can be done.
Lo-Fi Version Time is now: August 11th, 2026 - 10:58 PM
