Sep 2, 2004 - 5:44 PM
Enthusiast ![]() ![]() ![]() Joined Mar 9, '03 From Orting, WA Currently Offline Reputation: 0 (0%) |
I have issues with bottoming out bad ever since i got my invader kit. I think bigger rims will fix that problem, what do u think?
I wanna go 17" but i wanna go wider then factory, how wide do u think i can go, i plan on getting fenderflares too. |
Sep 2, 2004 - 5:53 PM
I'd get the fender flares first, and then worry about rims. Then you can get rims with the correct width and offset.
Sep 2, 2004 - 6:56 PM
7.5" wide
Sep 2, 2004 - 7:35 PM
TTE has 17X8 and they look just about perfect...i cant remember the offset tho..
Sep 2, 2004 - 8:36 PM
see thats where im confused, what do u mean by offset?
Sep 4, 2004 - 11:15 PM
Enthusiast ![]() ![]() Joined Aug 22, '04 From Menomonie, WI Currently Offline Reputation: 0 (0%) |
imagine the letter I. Its like a cut away of a rim. the offset is where the vertical part is in between the outer band. you can have this moved to make the wheel tuck in closer to your car, or away from it. most of the time its not a big deal, but if your going wider, thats when it comes into play.
| Lo-Fi Version | Time is now: June 16th, 2026 - 12:25 AM |
