> yet another Alarm??, +or - triggered??
post Mar 5, 2003 - 5:27 PM
t96f
Joined Sep 30, '02
From NS Can
OK so I'm about to do my alarm and am lazy,,, any one know if our Parking lights, door locks, interrior lights are positive or negative triggered.. THANKS the help will be GREATLY appreciated... biggrin.gif
Replies (1 - 10)
post Mar 5, 2003 - 5:46 PM
AudioFreak
Joined Dec 19, '02
From West of Atlanta
If I remember right they are all negative trigger.
post Mar 5, 2003 - 9:15 PM
t96f
Joined Sep 30, '02
From NS Can
OK got everything up and running excaept the interior lights,, ahhKK tried eveything I could think but the won't come on ... any one got any ideas??
post Mar 5, 2003 - 9:48 PM
slowceli
Joined Oct 31, '02
From grants pass oregon
i ran a wire inside the fender and spliced into the sidemarker light. i was to lazy to find the right wire under the dash
post Mar 5, 2003 - 9:56 PM
t96f
Joined Sep 30, '02
From NS Can
that would work for the marker lights,, got them done, green wire behind dash dimmer,, found the red white wire on kick pannel for door switch,, just need to get domes to come on when shut of alarm,, frown.gif followed the directions to the T and yet nothing,, tried it a s apositive and as a negative switched connection niether worked,,,,
post Mar 5, 2003 - 11:00 PM
I got illuminated entry to work on my car just fine. The door sensors are negative triggered, and I had to use a relay to get mine to work. Did you use a relay, or just try tapping into the wire directly?
Here's a wiring diagram of what you need to do(from http://www.the12volt.com - Lots of great info there):
If that doesn't work, maybe you've got the wrong wire. Post again if it doesn't work and I'll take pics of the wire and stuff that you need to tap into. biggrin.gif
post Mar 5, 2003 - 11:45 PM
t96f
Joined Sep 30, '02
From NS Can
I knew YOU would have the answer... but only one prob.. my alarm is "sposed" to be able to do it on it's own.... ahh well I gots relays,, try it tomorow after work... THANKS
OH and the brown wire in the diagram that would be the red/white kick pannel wire right??
This post has been edited by t96f: Mar 5, 2003 - 11:50 PM
post Mar 6, 2003 - 1:43 AM
QUOTE (t96f @ Mar 5, 2003 - 8:45 PM)
post Mar 7, 2003 - 6:23 PM
t96f
Joined Sep 30, '02
From NS Can
OK now I done ****ed up BAAAD,, long story short I think I burnt out the diode for the interior lights on the drivers side DOOH!! I cut the red/white wire after and have power on both sides,, any idea whare the diode is?? HEEEELLLPPPPPP!!
post Mar 7, 2003 - 10:59 PM
QUOTE (t96f @ Mar 7, 2003 - 3:23 PM)
I'm not sure where the diode is at. What exactly happened?
post Mar 8, 2003 - 11:57 AM
t96f
Joined Sep 30, '02
From NS Can
Got it on 12volt to,, here ya go,, http://www.the12volt.com/installbay/forum_...?TID=10559&PN=1
Lo-Fi Version Time is now: May 18th, 2026 - 1:58 AM
