> koni shocks
post Sep 7, 2004 - 11:08 AM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
From Spring Valley, NY
anyone who has them(koni yellow shocks) can you please IM me...i need some info and kinda confused....
thanx
alex
AIM: Jigglypup18
Replies (1 - 5)
post Sep 7, 2004 - 11:21 AM
Ve1Ls1dEvolutioN
Joined Oct 19, '02
aite just to make it easier so i dont have to say it more than once...i have kyb gr2's shocks now but their dead and i need to replace them...i wan konis cuz their adjustable but the question is....do u get 2 cartridge for the rears and 2 whole housing for the fronts?? OR[B] do u get 4 cartridges?? someone told me that it was 4 cartridges and that the 2 fronts have to be welded...but importhorizon.com has told me that only 2 are cartrdiges....so i'm kinda confused...any answer would be greatly appreciated
thanx
alex
post Sep 7, 2004 - 11:32 AM
You get four shocks. The fronts aren't the problem though, as your KYBs were just shocks for the fronts as well. The problem is that you have to cut and weld your rear struts in order to remove the old shocks and put the Koni shocks in.
post Sep 7, 2004 - 10:12 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
No welding is required (provided you use OEM KYB rear struts). If you've got GR-2s, you will probably have more problems installing the Konis. Hopefully some other people will give you more information on GR-2 to Koni installation.
post Sep 12, 2004 - 11:31 AM
Shigexile
Joined Oct 30, '03
From IL
how long does the KYB struts last?
post Sep 22, 2004 - 11:23 AM
Andy_GTfour
Joined Nov 16, '03
From Italy - Como
i have installed custom Bilstein shock and eibach spring, 1800€, are not adjustable.
the koni adjustable shock with eibach spring costs 1.400€
but are all for gtfour.........
absorbers 1
absorbers2
absorbers3
Lo-Fi Version Time is now: June 14th, 2026 - 4:33 AM
