> T3 question, Wastegate
post Sep 7, 2004 - 9:03 PM
hyp3rk1d
Joined Sep 22, '03
Ok do you see the open port on the bottom of the wastegate?? is something suppose to screw into that or what?? Also that rod going from the compressor housing to the other port in the bottom of the waste gate, whats that for or do?? I know, I feel like an idiot asking but i dont know, sorry.. Thanks
post Sep 7, 2004 - 9:14 PM
DustyBurns30
Joined Jul 31, '03
From Panama City Beach, FL
seems to me that a nipple>hose barb should screw in there to run a vacuum hose to your bov. and the other vacuum hose i believe tells the wastegate how much air the turbo is pulling mechanically. that is just a guesstimate so somebody will have to back me up on that.
post Sep 7, 2004 - 9:23 PM
hyp3rk1d
Joined Sep 22, '03
thanks bro...
post Sep 7, 2004 - 11:33 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (DustyBurns30 @ Sep 7, 2004 - 6:14 PM)
that is not a port for the BOV
that, most likely, is there for some nissan boost sensor/controler, to read the boost pressure, or bleed pressure away from the actuator to allow for more boost
the BOV needs a vacuum line from the intake manifold, after the throttle body. if you hooked the BOV to the actuator for the wastegate, it would never let off.
the rod that has a vacuum line on it going to the actuator is the signal line. once enough boost is made, it forces the actuator to extend its arm, which is connected to the internal wastegate on that turbo you have pictured, allowing exhaust to bypass the turbine and limit the amount of boost the turbo will make.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Sep 8, 2004 - 6:14 AM
hyp3rk1d
Joined Sep 22, '03
Thank you 97... So your saying I can leave that port open like that?
post Sep 8, 2004 - 11:07 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
I would say ditch that crappy turbo and invest in something better that has more future potential for when you grow out of it...because you WILL. smile.gif
post Sep 8, 2004 - 12:03 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (hyp3rk1d @ Sep 8, 2004 - 3:14 AM)
no, you should plug it, that would be a huge boost leak and cause boost control problems
post Sep 8, 2004 - 4:03 PM
hyp3rk1d
Joined Sep 22, '03
what do u suggest i plug it with??
post Sep 8, 2004 - 4:18 PM
nik
Joined Sep 30, '02
QUOTE (hyp3rk1d @ Sep 8, 2004 - 2:03 PM)
post Sep 8, 2004 - 6:12 PM
DustyBurns30
Joined Jul 31, '03
eesh!!! i was way wrong, thanks for correcting me.
post Sep 8, 2004 - 8:17 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (hyp3rk1d @ Sep 8, 2004 - 1:03 PM)
auto parts stores sell plugs, they screw right in.
Lo-Fi Version Time is now: August 23rd, 2026 - 9:13 AM
