Sep 10, 2004 - 10:57 AM
Enthusiast ![]() ![]() ![]() ![]() Joined May 3, '04 From pittsburgh Currently Offline Reputation: 0 (0%) |
if i rebuild the 7a..what type of products should i use..like i'd wanted new pushrods, pistons, connecting rods, lifters, values and springs...anything else i should add to the list??..please help me out everyone
This post has been edited by OrbitalGT95: Sep 10, 2004 - 11:02 AM -------------------- ![]() Now SR powered |
Sep 10, 2004 - 1:02 PM
7afe doesnt have pushrods, lol -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Sep 10, 2004 - 1:44 PM
Enthusiast ![]() ![]() ![]() Joined Jul 27, '04 From phoenix az Currently Offline Reputation: 0 (0%) |
if ur gonna turbo it in the futur you might wanna go with a 4age head and intake manifold.
Sep 10, 2004 - 1:48 PM
That involves a whole lot of work though, like re-wiring the harness, using a custom timing belt setup, etc. If you were going to do that, you might as well just swap in a 4A-GE or 4A-GZE and then turbo that. A 7A-GTE would be a lot of work...just ask frotou. -------------------- New Toyota project coming soon...
Sep 10, 2004 - 2:26 PM
i wasn't planing on turboing it..i just wanted a good strong n.a engine..then maybe load some spray.....ya..my bad bout the push rods....anything else i should know
Sep 10, 2004 - 3:30 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
Well, if you don't want to turbo, next time write 7A-FE and not 7A-FTE.
Sep 10, 2004 - 4:40 PM
![]() Enthusiast ![]() Joined Apr 13, '04 From St. Louis (Webster Groves) Currently Offline Reputation: 0 (0%) |
I got this from the SVX owners group that im in.
From Danish_SVX of Subaru-SVX.net "I have a Celica as well, including my SVX. Make sure the engine you are getting hasn't been sitting outside in the rain, and make sure it hasn't been sitting with fluids indie of it. Make sure the fluids have been dumped out of it. If you don't mind spending money, "Jasper Engines" sells remanufactured with 36,000 miles 3yr warranties on their engines and they have plenty of Toyota. Getting an engine from a scrap yard always has it chances of being bad and full of rust if they haven't been used. It's also a good idea when pulling an engine out of a scrap car that you change all the belts: timing and serpentine. And re seal the oil pan, valve cover, and head gasket. From expierence I know it's quite invigerating to put Celica engines in. I've replaced two 5sfe in my Celica. Until I finally put a 3sgte (2.0L Turbo) in it which I feel is the best engine that yamaha ever made. I would also suggest changing the whole engine and not just the short block if you are going to replace something. In my opinion the best thing to do with your engine would be keep it. Bore it out and put some iron or steel cylinder sleeves in it, and replace the rod bearings to TOGA rod bearings which are alot stronger than the factory ones. Summitracing actually builds a rebuild kit for the 5sfe, 3sgte, 4afe, and the 7afe." Thought that might have some usefull information. -------------------- |
Sep 10, 2004 - 5:09 PM
hey thanks mk for pointing me in the right direction
Sep 10, 2004 - 7:41 PM
Youre quite welcome...
Sep 10, 2004 - 7:43 PM
hey coomer..where and how much did u find you engine??
Sep 11, 2004 - 1:43 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 10, '03 From FL Currently Offline Reputation: 0 (0%) |
i disagree. my dads 250 v-max hpdi is a bad ass jj buddy, my dads sponsored by yamaha, so we have lotsa boats with yamahas. |
Sep 13, 2004 - 2:43 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
He Got it from Venus auto, and he will probably send you to Jarco inc.
| Lo-Fi Version | Time is now: September 2nd, 2026 - 5:30 AM |
