> Squeaky clutch?
post Sep 12, 2004 - 8:55 PM
Delta_Phoenix
Joined Oct 16, '02
From Hohenwald, Tennessee
For the past couple of months, I've noticed a squeaking noise whenever I engage and disengage the clutch. I've only been able to notice it while idling. It doesn't always happen, but more often than not. Whether or not it does it while driving is a different story, I can't hear it over the sound of my engine.
post Sep 12, 2004 - 10:15 PM
mikew04
Joined Feb 19, '04
From austin tx
I have the same problem. It can get pretty annoying
post Sep 12, 2004 - 10:54 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
Wow, I thought I was the only one....lol
Sometimes its real loud, and other times I cant even hear it, but everything still works perfectly fine for me anyway. I'm guessing its just an old bushing or something.
post Sep 13, 2004 - 7:09 AM
post Sep 13, 2004 - 10:16 AM
stelica85
Joined Jan 16, '03
From Wichita KS
i thought that could be it because i have the same problem and my clutch is pretty worn. when i replace it it will be replaced as well so i'm not sweatin it
post Sep 13, 2004 - 3:26 PM
mikew04
Joined Feb 19, '04
From austin tx
So is there anything we can do to fix this?
post Sep 13, 2004 - 3:28 PM
QUOTE (mikew04 @ Sep 13, 2004 - 1:26 PM)
Well, you have to pull off the tranny to replace the throw-out bearing, which is not a fun job.
post Sep 13, 2004 - 3:37 PM
fastgt
Joined Feb 13, '03
From California
when i changed my clutch i couldnt find the right throw out bearing....anywhere....turns out i have a tranny from a camry and the bearing is slightly bigger than our celis
but yeah that noise should be the throw out bearing and its long and tedious to change
This post has been edited by fastgt: Sep 13, 2004 - 3:43 PM
2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3
gone but not forgotten
2008 Space Grey BMW Z4 ///M
post Sep 13, 2004 - 3:49 PM
jontechie
Joined Oct 25, '02
From London- England
I had this problem on two occasions, first was sourced to the pedal lever
mechanism (usually a common feature on imported vehicles which are exposed
to the sea air on the boat). A good can of WD40 and lots of elbow grease eventually will get rid of the noise. The other cause where the noise comes
from the engine bay will usually be due to the clutch slave cylinder.
Follow the clutch fluid resevoir to the first cylinder (master) then follow
the fluid line to the slave cylinder near the front of the engine, need a good
torchlight to see this. You may have to take any relay boxes etc to get
your arms down into that area. Get someone to pump the clutch pedal and
at the output end of the slave cylinder there is a rubber boot (the cylinder has a rod which moves an arm).Get your WD40 again and spray generously at the
point the rod moves in and out of the slave cylinder.When the noise subsides just
replace the boot and thats it. Hope this helps,
Jon
post Sep 13, 2004 - 4:18 PM
Delta_Phoenix
Joined Oct 16, '02
I don't think it's from any of my parts being worn. I just had the clutch, throwout bearing, and pressure plate replaced about a year ago. Maybe when I'm not so lazy I'll dig a hole, fill it with WD40, and drive my car into it.
post Sep 13, 2004 - 10:37 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
i have the same problem once in awhile also it comes and it goes.
post Sep 14, 2004 - 9:06 AM
toyotatech3
Joined Jul 30, '04
From colorado
before u pull the transmission try replacing all the bushings on the pedal, iv'e replaced hundreds of bushings because of a squeaky clutch.
post Sep 14, 2004 - 10:18 AM
boosted_K2
Joined Aug 30, '02
From Michigan
ya i have the same problem, but it sounds like its coming from down at the pedals, not in the back of my car, i can also feel some resistance... mine is definatly the bushings
No but I don't buy it
Cause I'm...
Lo-Fi Version Time is now: August 26th, 2026 - 8:08 PM
