Sep 12, 2004 - 10:05 PM
Enthusiast ![]() ![]() Joined Aug 26, '04 From St. Cloud, Minnesota Currently Offline Reputation: 0 (0%) |
I heard from a topic about a month ago that a boosted convertable is not a very good idea because the frame is weak and can't handle the extra torque say around 8PSI. Is this true? Before I start saving for a turbo/supercharger kit, I just want to know will a convertable hold up to the extra power? If it won't then i'll just go show with some simple bolt ons.
Sep 12, 2004 - 10:15 PM
Its an unknown. But you may want to ask again in a week.
Chassis Flex Post This post has been edited by jgreening: Sep 13, 2004 - 8:22 AM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Sep 12, 2004 - 10:24 PM
If the convertables are bad for boost, then how come some s2000's are running on vortech superchargers and 12+psi boosted? aren't all convertables the same?
Sep 12, 2004 - 10:26 PM
No. Convertibles like the Vette and the S2000 were designed to handle the horsepower - that is, they were designed as convertibles. Our cars were once coupes that got the tops cut off in California by a company called American Sunroof Company (ASC). The roof in a standard car provides much of its ridgity - when you cut it off, the ridgity is lessened significantly. ASC did provide some structural enhancements but they were all rear of the lock pillar. The flex is going to occur in the front cowl.
This post has been edited by jgreening: Sep 12, 2004 - 10:28 PM -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Sep 12, 2004 - 10:30 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) |
It should be ok; your car isn't going to snap in half. I'd start doing chassis bracing tho; DG sells some stuff.
![]() Enthusiast ![]() ![]() ![]() Joined Dec 4, '03 Currently Offline Reputation: 0 (0%) |
you cant compare a sports car like a s2k or 350z vert to a celica. they are made different each vert frame is ment for a purpose in which case the celica is ment for around 125 hp.
-------------------- hows it taste motha f*cka |
Sep 12, 2004 - 10:48 PM
is there anyone on this forum with a boosted convertable? I want to know how it is working for them and what did they have to mod or fix any problems they had.
Sep 12, 2004 - 10:54 PM
Gosh... you guys really are pretty paranoid. If the Celica vert can't handle boost... then it shouldn't even be on the road. The chassi is NOT gonna flex outta control or anything like that, if that's what you're reffering to. Sure, it flexes a bit more compared to a Hatch or a Coupe, but it's nothing that will somehow make the car dangerously unstable because of the added torque/power of boost...
And... DG Performance has a 3SGTE vert I believe... -------------------- "It's ok to be naked girl... I'm an artist!"
Sep 12, 2004 - 11:00 PM
No one said it was going to be dangerous. The question is will it lose ridgity over time. For my sake, I hope you are right Kwanza and there will be no problems.
Sep 12, 2004 - 11:03 PM
After waiting about 80 days, I am picking up my 3sgte swapped convertible Friday. I believe I am the only one that regularly posts on this site that has (will have) a boosted convertible. DG has a hatch. There are two 3sgte powered 5th gen that members of celica.net own. One has a 4 pt roll cage though. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Sep 12, 2004 - 11:22 PM
Jgreening, and everyone else thanks for all the inputs and advice.
Jgreening let me know how you like the boosted convertable and how it feels when u have it. Thanks in advance. |
Sep 12, 2004 - 11:39 PM
There should not be a problem. Any car that is made as a vert should be able to handle any good amount of power... There body is made dif then norm. and should, Is I would say at least handle around 300hp
Sep 13, 2004 - 12:21 AM
wow if you say they can handle around 300HP then i guess i don't have anything to worry about. I'm only planning on running around 8-10 PSI which I think would be around 200-220 HP.
This post has been edited by hs2g: Sep 13, 2004 - 12:21 AM |
Sep 13, 2004 - 2:19 AM
people the vert have reinforced frames.. which means they are a lot stronger then coupes and hatches...so go boost away.. and if your still scared.. drop in a roll cage and engine dampners.. and stronger motor mounts..
Sep 13, 2004 - 2:35 AM
Enthusiast ![]() ![]() ![]() Joined Dec 2, '02 From Portland, Oregon Currently Offline Reputation: 0 (0%) |
What Gen motor are you planning on swapping? Is that at the crank or to the wheels? |
Sep 13, 2004 - 9:57 AM
Sorry Mac, but even with the reinforced frame, we're still worse off than a coupe or a hatch. As for that 300 hp comment.. I wouldn't trust it. |
Sep 13, 2004 - 9:14 PM
I'm not planning on swapping a motor. I have a 5sfe with 74800miles on it. I was planning on doing a custom turbo. Running around maybe 5PSI on daily and 8-10PSI on random races with some friends of mine. Maybe ungradeing the pistons and rods. |
Sep 14, 2004 - 8:24 AM
Enthusiast ![]() ![]() ![]() ![]() Joined May 3, '04 From pittsburgh Currently Offline Reputation: 0 (0%) |
DG has a gt hatchback not a vert
-------------------- ![]() Now SR powered |
Sep 14, 2004 - 8:49 AM
There is an echo in here. -------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
| Lo-Fi Version | Time is now: August 27th, 2026 - 1:03 AM |
