> Dome Light! Please Help, What's going on?
post Sep 14, 2004 - 12:58 PM
UniStorm
Joined Oct 17, '03
From Huntsville, AL USA (Born and Raised in NY)
My dome light comes on whenever I hit a bump or stop short. Anyone esle has had this problem? please help.
post Sep 14, 2004 - 1:03 PM
Probably a short, check the switch on the inside of the door jamb.
post Sep 17, 2004 - 12:05 AM
mr_dude
Joined Feb 16, '04
From San Diego
If your dome light has been somehow mistreated the switch in the dome light could be loose. When you jerk the car two contacts meet and the light goes on.
post Sep 17, 2004 - 12:22 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
check to make sure the bulb's not loose
post Sep 20, 2004 - 6:39 PM
jbnery6465
Joined Sep 14, '04
From SaN DiegO, CaLi
just take them out...haha j/k...yah just check to see if they're on right...
post Sep 20, 2004 - 11:54 PM
mr_dude
Joined Feb 16, '04
From San Diego
The light shouldn't be going on if the bulb is loose.
But Sprynt has a point.
If:
a. your dome light switch is set to "Door" and you hit a bump, the door switch might be triggered (because it's loose, perhaps). That is, the dome light thinks the door is open because the sensor is loose.
b. your switch is set to "Off" then a. can't happen. There then is probably something wrong with the light switch. This shouldn't be because the assembly is pretty solid.
post Sep 22, 2004 - 12:57 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
if it's loose yes it can becuase when he hit a bump it gets contact with the metal and then gravity pulls it back down.
Lo-Fi Version Time is now: September 2nd, 2026 - 4:18 AM
