> what else?, more mods
post Sep 14, 2004 - 8:17 PM
brys99
Joined Aug 7, '04
From Ohio
i'm very new to the car performance scene and i was wondering what else i can do to my car to make it run more efficiently. what other mods can i put on my car to make it faster, more gas efficient, and look and sound better. i have the cold air intake and exhaust...i'm just dont know much about the inside of the car to know what else to do. any suggestions would help. thanks
post Sep 14, 2004 - 10:46 PM
spunky393
Joined Apr 22, '04
From illinois
Did you try searching?
post Sep 14, 2004 - 10:51 PM
Ale_lock
From New York City, NY
QUOTE (brys99 @ Sep 14, 2004 - 9:17 PM)
You need to figure out what you want first. Looks: Try looking around in a sticky post in the Exterior section (click meh). As for faster, gas efficient, sounding better: With a CAI (you sure you got a CAI & not a Short-ram intake? just double checking) & Exhaust, you should have a good sound, as for a faster engine & fuel efficient, you can't have both.
Edit: Correction, you can make it efficient at burning gas faster. tongue.gif If you want it to be gas efficient, leave the car alone, as for faster speeds? try searching around cause there's a lot of options to explain from making hybrid engines to putting a turbo on your current engine to just swapping out, all depends on your budget & how far you are willing to go.
Ideas for engine swaps
How to for turboing a 5S-FE (Celica GT engine)
Some information to start you off, read some of that & just ask what ever questions come up.
This post has been edited by Meonspeed: Sep 14, 2004 - 11:00 PM
post Sep 15, 2004 - 11:24 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
you got a lot of research ahead of ya if you like reading about it it'll go by fast and you just want to keep reading.
post Sep 15, 2004 - 2:26 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
ill actuatly give you a direct answer and say.
- pullys
- safc and tuned
- stand alone management
- new fuel rails
- bigger TB even though this is an endevour
- nos
- velocity stacks
- regrinded cams
- advance your timing
- new spark plugs
- new spark wires
- grounding kit
- new ignition setup
- head work (to much within this to name
- port your intake manifold
- 2jz-gte valves
- lightened flywheel
- and lightening your car.
wow i never knew there were that many
theres a lot more im just forgeting
just go play some NFSU itll help you out. im work on getting some money for my level 2 turbo setup.
This post has been edited by recneps: Sep 15, 2004 - 2:28 PM
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Sep 15, 2004 - 2:28 PM
GReddy4u
Joined Mar 20, '04
From North Carolina
performance clutch, taking out back seats helps some also
Lo-Fi Version Time is now: August 27th, 2026 - 9:24 PM
