> fuel injectors, 7mge injectors
post Sep 15, 2004 - 11:54 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
allright i have the yellow top fuel injectros from a 1989 7mge engine i went to go see if the clips matched up and they did not. what do i have to do here. these should work right
thanks
This post has been edited by rjbibeau: Sep 15, 2004 - 11:54 PM
Replies (1 - 5)
post Sep 15, 2004 - 11:58 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
You need the greentops.. there actually kind of a light yellowish green
here is a link to another thread of mine.. in there is a link to a site that has all kind of info for toyota injectors.. it will show you the difference between the yellow and lime green ones
greentop flow rate thread
post Sep 16, 2004 - 12:05 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
and what kind of car can they be found on?
these are the same ones i have are these the ones
injectors
This post has been edited by rjbibeau: Sep 16, 2004 - 12:10 AM
post Sep 16, 2004 - 11:51 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
bad link there... here are the type and part number you want
there off the MKIII non turbo supra.. 87.5 - 92 I believe, they came with the yellow tops or the Green tops.. the blacks are for the Turbo version wink.gif
This post has been edited by NEVERSTOP: Sep 16, 2004 - 11:52 AM
post Sep 16, 2004 - 3:21 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
those look like the ones i have i'll go check the part number. but on mine the clip does not clip into the 5sfe injector harness
post Sep 16, 2004 - 3:43 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
allright those aren't what i have. my part number on my injectors are 23250-20040 but when i bought them they said they were from a na 89 supra with a 7mge engine this has got be stumped
Lo-Fi Version Time is now: August 29th, 2026 - 2:47 PM
