> Celica St 97, Fuel & water system
post Sep 20, 2004 - 2:44 PM
gpennesi
Joined Sep 20, '04
From UK
would anyone know where i can get hold of diagrams for the fuel & water system for a Celica Gen 6 st 97..
The engine has been rebult but i forgot which pipes go where..
post Sep 20, 2004 - 6:40 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (gpennesi @ Sep 20, 2004 - 7:44 PM)
They only fit on one way. For the water, there is the small "U" shaped inlet pipe that goes from the head to the waterpump, then there is the outlet connector next to the exhaust manifold. Behind that, on the back of the head, is the main inlet.
For the fuel, the injectors are on the manifold on the fuel rail, and there are various lines that run off of that. Exactly what are you looking for? Most of the stuff only fits one way.
post Sep 21, 2004 - 8:28 AM
gpennesi
Joined Sep 20, '04
From UK
The head gasket and piston rings were changed. So the engine was removed..
Unfortunately none of the pipes were marked.
The vacume pipes are mixed with the water pipes and also the fuel pipes.
Just below the air inlet that the air filter fits onto there are 3 lines. Im not sure what goes onto these...and above at the top what looks like a small vacume line..
Also near the water pipe there are 2 very small lines sticking out ( blue in color I belive these to be vacume pipes where do these go..?
I have one small pipe that comes from the charcoal filter...
Also at the start & end of the fuel rail there are lines im not sure what pipes go on this..
I have contacted toyota to send me some sort of piping diagrams but they still havent sent me anything..
To be honest im no expert on this only an amateur !!!!
Lo-Fi Version Time is now: July 11th, 2026 - 11:29 AM
