> Engine Problems :(
post Sep 20, 2004 - 5:26 PM
GaiaTCO
Joined Aug 9, '04
From Atlanta
Looks like more trouble has come guys frown.gif the engine wont even start now sometimes. I get in the car and i try to start her but she just wont turn over. I changed the battery just for the hell of it even tho i know it isnt a battery problem. This has happened to me about 6 times now. What do you guys think because this looks pretty serious like something is about to fail or is heading towards failure. Thx in advance for your help.
post Sep 20, 2004 - 5:46 PM
could be dist. cap, wires, plugs, injectors, fuel pump...you need to eliminate this stuff one by one.
post Sep 20, 2004 - 5:51 PM
GaiaTCO
Joined Aug 9, '04
From Atlanta
Changed the distributor cap, wires and spark plugs recently, fuel pump and injectors are fine cleaned them a couple of months ago too
post Sep 20, 2004 - 6:10 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
post Sep 20, 2004 - 6:19 PM
yeah but thtas probably what he's hearing crankin.
post Sep 20, 2004 - 6:24 PM
you have to test things out one by one....
if you rear your starter turing, then next thing to do is check for spark. take out one of your sparkplug wires and have somone hold it close to any metal part of the enigne by the rubber boot. then crank the engine and have a friend check if there is a spark being created between those 2 points.
if you get spark and the car is still not starting, then it must be a fuel problem.
if the car starts, and then dies right off, then it could be a blocked egr valve or sometimes even the o2 sensor.
post Sep 20, 2004 - 6:30 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
a bad starter can still crank over and not start... sounds like his starter is starting to go.
post Sep 20, 2004 - 6:32 PM
if you do a spark test you gotta hold it ON the block, grounding it.
As for the starter, does it sound right?
post Sep 20, 2004 - 6:38 PM
QUOTE (Supersprynt @ Sep 20, 2004 - 4:32 PM)
hehehe thats what i ment.... you know i know the spark test, haha i failed mine many times that day you were there...hahaha
post Sep 20, 2004 - 6:43 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Guys... I don't think it's the spark. He did say only "sometimes"... If it's his spark, the car would crank and not start at all... then again, he's quite vague about the exact situation.
post Sep 20, 2004 - 6:47 PM
jbnery6465
Joined Sep 14, '04
From SaN DiegO, CaLi
had the same problem...theres a bolt in your starter which actually engages with the starter when you turn the key...it could be burned down and need to be replaced. go to any toyota dealer and get a new one....hope that helps.
post Sep 20, 2004 - 6:57 PM
funnyboy117
Joined Mar 9, '04
From San Carlos, CA
When my starter went out I would turn the key and nothing would happen. Even after I fully recharged the battery. It took a lot of tries to get it to even turn over, and then it started in a jiffy.
post Sep 20, 2004 - 7:25 PM
celicaboston1983
Joined Mar 20, '04
might want to check fuses too. In my alltrac car wouldnt start thought it was the started but check all the fuses and one of them blew. Changed the fuse and its started fine.
post Sep 20, 2004 - 10:56 PM
GaiaTCO
Joined Aug 9, '04
From Atlanta
well when it doesnt start the engine doesnt even crank i turn the key and nothing happens
post Sep 20, 2004 - 10:58 PM
GaiaTCO
Joined Aug 9, '04
From Atlanta
QUOTE (funnyboy117 @ Sep 20, 2004 - 11:57 PM)
my problem sounds alot like his
post Sep 20, 2004 - 11:10 PM
jbnery6465
Joined Sep 14, '04
if you dont hear the engine crank or the battery even pushin...do you hear like a "clicking" sound when you turn the key...i mean like a hard click...like..."CLICK" coming from the middle of the engine? if you do you might have to take out the starter and check that brass bolt that i was talkin about...those clicking noises get me paranoid...
post Sep 20, 2004 - 11:26 PM
GaiaTCO
Joined Aug 9, '04
From Atlanta
nope no clicking its dead silent when i turn the key the only way i know the battery is still good is because i could run the radio and headlights and i put a new one in anyway so its got to be good :/
post Sep 21, 2004 - 12:02 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
hook up 12v to the signal line on the starter and see if it cranks every time you do it
if not, the starter is bad
if it works
then you have problems in the key cylinder
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Sep 22, 2004 - 5:59 PM
GaiaTCO
Joined Aug 9, '04
From Atlanta
oh this is great the car started again when i tried just for kicks this is mind boggling
post Sep 22, 2004 - 6:32 PM
Hanyo
Joined Aug 16, '03
From Bay area
yea it sounds like a key cylinder problem..
you should look into that before it causes you to be strained in a parking lot.
Lo-Fi Version Time is now: September 1st, 2026 - 11:18 AM
