> Question for those who have install Koni's, themselves
post Sep 24, 2004 - 10:25 PM
Einhander
Joined Oct 23, '03
From ky
I am about to install the front koni inserts, i know you have to cut the housing. But my question is How far down do you cut, or does it matter? (i would just normally remove the nut, But its ground down because of coil-over install)
post Sep 24, 2004 - 10:32 PM
BLINKYxMUNKEY
Joined Nov 12, '03
From Crestview, Florida
i am about to install my konis in like a week. ill try to find out.
FlickR
post Sep 25, 2004 - 8:02 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
You don't have to cut anything to install the fronts; you will need to cut the housings on the rear struts only. I don't remember the exact amount, but Koni should supply instructions.
post Sep 25, 2004 - 11:09 PM
Einhander
Joined Oct 23, '03
From ky
I have it done now, But the nut to remove the stock housing was ground down for the coil-over install, So i had to cut the housing.
Lo-Fi Version Time is now: June 10th, 2026 - 6:13 AM
