> Help!, engine problems? :(
post Sep 24, 2004 - 11:12 PM
Rider
Joined Feb 3, '04
From West Windsor, NJ
Hi, I haven't posted much on this forum since I registered frown.gif mainly b/c I haven't had time or money to do anything to my car, but I'd really appreciate your opinion on this. I have a 94 celi gt with 110k miles and when I drive it I can hear a metallic rattle coming from under the hood under acceleration, sometimes at low and sometimes at high RPM. This doesn't happen all the time, but it has become more frequent over the last few months to the point where now I hear it almost every time I drive the car. Has anyone had this problem or know what's wrong? Thanks
post Sep 24, 2004 - 11:34 PM
shid
Joined Jan 8, '04
From LA
from your profile:
Performance:
K&N air filter with chrome intake pipe
I can almost guarantee (95%) thats your problem, my injen intake rattled til I put a little padding where it was hitting the side of the bay;
it's becoming more frequent because your clamps are getting looser, and letting the intake move more. Tighten up the clamps, and then see where the intake is hitting something, and then either pad that, or secure the intake better?
This post has been edited by shid: Sep 24, 2004 - 11:34 PM
post Sep 24, 2004 - 11:40 PM
Rider
Joined Feb 3, '04
Nope, that can't be it. I installed the k&n filter today. However, before the k&n I used a cheap k&n immitation filter, which might have done damage to the engine??? confused.gif
This post has been edited by Rider: Sep 24, 2004 - 11:41 PM
post Sep 24, 2004 - 11:48 PM
Rider
Joined Feb 3, '04
Before the celi I drove an 88 subaru which if I remember correctly made the same kind of noise when going up a hill, which was also associated with burning oil like crazy and a thick cloud of white smoke coming out of the exhaust. In my car it's just the noise.
This post has been edited by Rider: Sep 24, 2004 - 11:48 PM
post Sep 25, 2004 - 1:11 AM
shid
Joined Jan 8, '04
From LA
nono, the chrome pipe is what is probably hitting.
post Sep 25, 2004 - 1:14 AM
Doge
Joined Dec 2, '02
From Portland, Oregon
Sounds like detonation to me
post Sep 25, 2004 - 10:00 AM
Rider
Joined Feb 3, '04
QUOTE (shid @ Sep 25, 2004 - 6:11 AM)
shid, before I installed the k&n filter there was no chrome pipe, just the rubber tube that came stock, and it made the same noise back then too. what do you mean by detonation Doge?
This post has been edited by Rider: Sep 25, 2004 - 10:02 AM
post Sep 25, 2004 - 10:02 AM
97GTinKC
From KC
Definitely sounds more like detonation or pinging, might try a better grade of fuel. Or some combustion chamber cleaner, may have some carbon build-up raising the compression. (or possibly check the timing, may have too much advance?)
post Sep 25, 2004 - 10:42 AM
shid
Joined Jan 8, '04
From LA
QUOTE (Rider @ Sep 25, 2004 - 3:00 PM)
Since the intake rattles more at high RPMs and high speeds; and builds up rattling over time, it was a good guess..
I dont think it sounds like detonation; what ur describing seems a little less intense than that. My guess is, if it's not the intake coming undone; it's something else.
post Sep 25, 2004 - 10:52 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Open the hood and listen. It could be detonation, valves, or worst, rod knock...
post Sep 25, 2004 - 11:00 AM
Rider
Joined Feb 3, '04
what's really annoying is that sometimes it makes the noise when the car starts moving from a stop and then the rattle is louder. what I also noticed is that the higher the RPM the higher the frequency of the rattle.
Rider
Joined Feb 3, '04
QUOTE (Kwanza26 @ Sep 25, 2004 - 3:52 PM)
It doesn't do it at idle or when I rev up the engine, I can only hear the noise if the car is in gear and accelerating. Sometimes it drives perfectly normal which is very confusing and sometimes it makes that noise...I don't know what to think but thanks for all the replies so far.
This post has been edited by Rider: Sep 26, 2004 - 12:19 AM
post Sep 25, 2004 - 1:02 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (Rider @ Sep 25, 2004 - 4:00 PM)
Turn up the rpms under the hood... pretty straight foreward. Anyway, because it doesn't do it at idle... this increases the chances of it being a rod knock...
Lo-Fi Version Time is now: August 29th, 2026 - 3:40 PM
