> retard timing?, obd II
post Sep 29, 2004 - 10:52 PM
Hanyo
Joined Aug 16, '03
From Bay area
how do you retard the timing on an obd II 7afe ecu for a force induction set up?
i might as well add to this...
does port and polishing the 7afe head affect its ablility to pass smog? what about increasing compression?
This post has been edited by Hanyo: Sep 29, 2004 - 11:01 PM
post Sep 29, 2004 - 11:34 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
port and polish doesn't increase compression.
on celica.net there is a how to on retarding timing.
This post has been edited by rjbibeau: Sep 29, 2004 - 11:34 PM
post Sep 30, 2004 - 1:15 AM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (rjbibeau @ Sep 30, 2004 - 4:34 AM)
of coarse port and polish doesnt increase compression.. i'm asking two different question.. does A) port and polish affect smog B) does increasing compression affect smog..
and some more information.. i specified obd II cuz the distributor cant be adjusted like obd I.. so the celica.net how-to is useless.
no one seems to know how.. i've asked before and i have never gotten an answer.. if you cant retart the timing.. how do you turbo you car with out knocking?
but thanks for the reply.
post Sep 30, 2004 - 1:21 AM
shid
Joined Jan 8, '04
From LA
obd-ii is non intrusive; it can't change the functions of the car.
post Sep 30, 2004 - 3:47 AM
Hanyo
Joined Aug 16, '03
From Bay area
thanks for the reply shid,
but you do not own a 7afe and you dont know what i am talking about.
pre -obd II distroputers allow you to loosen the bolt so you can turn the distributor so you can retard or and advance the timing..
obd II distributer do no have this function.. you can not loosen this bold and turn the distributor.. the distributor can not move for adjustment. (at least to the extent of my knowledge)
let me repeat it agian for those that do not understand..
post Sep 30, 2004 - 11:54 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
ya really that is a good question with obII how in the heck are you supposed to retard the timing...
post Sep 30, 2004 - 12:13 PM
nik
Joined Sep 30, '02
i did a search i beleive you can buy a crane retard timing unit or msd not sure if they work on obd 2 vehicals and http://www.babcox.com/editorial/ic/ic80040.htm i came across i dont know if it will help but has info on obd 2 stuff
This post has been edited by nik: Sep 30, 2004 - 12:54 PM
post Sep 30, 2004 - 12:36 PM
shid
Joined Jan 8, '04
From LA
Hanyo, your original question was how do you retard timing using OBD II; which I took to meant you wanted to hook a computer up and program your ECU with it to retard the timing, to this I told you OBDII is non instrusive (as OBDII is the same (minus interface differences from Toyota to Ford etc) on every car.
There was really no need for the "you don't know what you're talking about reply" since I answered your question, just not in the way you wanted it.
post Sep 30, 2004 - 2:49 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
bam he told you
post Sep 30, 2004 - 3:30 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
obd2 is pretty good about puting your timing where it needs to be
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Sep 30, 2004 - 4:04 PM
nik
Joined Sep 30, '02
QUOTE (97sccelica @ Sep 30, 2004 - 1:30 PM)
so you think its smart enough to retard the timing a few degrees???
post Sep 30, 2004 - 4:53 PM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (shid @ Sep 30, 2004 - 5:36 PM)
i did not say ANYTHING about using or adjusting OBD II system.. BUT i did say how do you adjust the time of a 7afe engine with the obd II "version" ecu.
clearly you can tell the obd II version of the 7afe ecu adjusts timing automatically. So if i wanted to adjust the timing i would have to go through the ECU.. not the obd II system.
post Sep 30, 2004 - 9:14 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (nik @ Sep 30, 2004 - 1:04 PM)
ecu controls timing based on sensor inputs, there is no adjusting it with out a ECU reflash
Lo-Fi Version Time is now: September 2nd, 2026 - 6:55 AM
