> 94 ST to GT all disc brakes, GT performance brake calipers
post Sep 30, 2004 - 7:45 PM
BigJ
Joined May 21, '03
From Louisiana
Im converting my ST to all disc brakes. I bought cross drilled/slotted rotors for the GT......now i need the calipers all the way around. Ive looked around but cant really find any performance calipers for the GT. Do you guys know any?
This post has been edited by BigJ: Sep 30, 2004 - 8:34 PM
post Sep 30, 2004 - 9:31 PM
They don't make performance calipers for the GT. You'll have to get OEM ones from somewhere.
post Sep 30, 2004 - 9:49 PM
crazycel18
Joined Jun 22, '04
From portland OR
i could swear that brembo makes a set for the gt calipers front and rear
There Ain't No Party Like A Celica Party
A Day Without Celica is Like a Day Without Sunshine.
post Sep 30, 2004 - 11:15 PM
Ale_lock
From New York City, NY
QUOTE (crazycel18 @ Sep 30, 2004 - 10:49 PM)
Not for our cars & only front brakes for the 7th gens.
post Oct 1, 2004 - 6:09 PM
TOYOCE409
Joined May 14, '04
From Port Arthur. TX.
So the GT rotors are bigger than the ST cause I also bought GT rotors. I heard that they might have an adaptor from the caliper to the knuckle.
post Oct 2, 2004 - 12:17 AM
snadman
From Minnesota, USA
Not sure, but use the 7th gen GT brakes if you're going throught he trouble converting.
95 Toyota Celica GT
Dead for now --> Soon to have a 3S-GTE
02 WRX --> This is for speed
- Borla Exhaust
- TurboXS BOV
- Custom CAI
02 Civic EX
- MB Quart Reference 5.25" Components
- Rockford MTX 8" Subs in the doors
- Alpine Type S Rear Fills
- 2x Alpine SWR-1042D Subs in a custom fiberglass box
- Alpine F345 Amp for the front doors
- Alpine M605 on each Type R
- Phoenix Gold wiring
- Alpine CDA-9855 Head Unit
- Alpine Amp link
- 2x Rockford Fosgate 1 Farad Caps
- The best Viper 791 alarm install ever
post Oct 2, 2004 - 11:55 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (TOYOCE409 @ Oct 1, 2004 - 11:09 PM)
Just get GT calipers... forget adaptors. These things are gonna stop your car... so would you really want to trust an adapter?
As for big brakes... Brembo does make a 4 pot caliper for the 7th gen, that should fir the 6th gen. It's also labed under TRD... so if you got a spare 2k to spend... let us know if it works out... ;]
post Oct 2, 2004 - 12:06 PM
BigJ
Joined May 21, '03
From Louisiana
hehe.....no i dont have 2k to spare......i barely have enough to spare to get the GT calipers LOL. I am about to attempt 3sgte swap and I gotta save as much money as i can for that. I got some 5th gen GT calipers coming off a parts car im getting....im gonna try those. Thanks for the help guys!
post Oct 18, 2004 - 9:44 AM
Nemises
Joined May 6, '04
From antioch CA
I just finished this swap. The GT brakes should fit right on but your supposed to get new backing plates the GTs are bigger than the ST however they do fit on barely without them. All I did was grab a set of calipers from the junkyard sand the rust off and spray with High temp paint they look clean. I also have a complete parts list with numbers you will need for the conversion. Once I get home I will post it for you. But i'll tell you first hand even without performance calipers you'll luv those brakes. The cross drilled matched with some ceramic pads will have your celi stopping at the drop of a dime trust me. Any questions feel free to holla at me.
post Oct 18, 2004 - 10:56 AM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
so you put GT rotors on the front of your ST?
post Oct 18, 2004 - 12:36 PM
Nemises
Joined May 6, '04
From antioch CA
Yup! The only thing the front needed was new backing plates and calipers. And every thing bolted right on. I still plan on getting the g stop steel braided hoses but they are on back order.
post Oct 18, 2004 - 12:39 PM
Nemises
Joined May 6, '04
From antioch CA
Oh I forgot if you do not have at least 15 inch rims on yout car the GT brakes will not fit I know most STs come with 14 inch rims. If you have stock rims you will need a new bigger set to fit your wheel on.
Lo-Fi Version Time is now: May 15th, 2026 - 9:19 PM
