> Fuse problem
post Oct 10, 2004 - 2:27 AM
ShadowFX
Joined Jan 22, '04
From WA, Australia
I bought some interior neons yesterday (they were on special,, bout 75% off) and i tried installing them today. Ive got them wired up to a switch, and when i connected them up using alligator clips it worked fine, so i soldered it all in, i leeched power off the cig. lighter.. it worked fine for a while, then about 10 minutes later, they wouldnt turn on.. it was the fuse for the cig lighter and radio. okay, so i swapped this for a new one, then as soon as i turn the ignition, they dont turn on again. the fuse blew straight away. this happened once more as i replaced the fuse. whats going on? I taped off all open connections, so im pretty sure nothing can short circuit. could it be that because i leeched off the cig lighter, its overpowering the entire system?
EDIT- I tried rewiring everything just then, found out when it happens. it works fine if i turn on the car with the switch on, but when i turn off the switch the fuse blows.. the plot thickens. maybe it gets easier. i dont know. anyone?
This post has been edited by ShadowFX: Oct 10, 2004 - 4:26 AM
Lo-Fi Version Time is now: August 11th, 2026 - 11:29 AM
