> celica dosent start
post Oct 10, 2004 - 11:36 PM
62-1celi
Joined Sep 14, '04
From miami
my car take forever to start so i check the spark it was ok...i check the furl pump that was ok .....i turn the key like 100 time and every time it well go to like 500 rpm and then die.....but then if it like it warmed up and then it goes to like 1000....then i'll rev it and it cant go pass 1000 rpm....so what i did want when it got to 1000 i put it in drive and then go then ill give it gas and it well like balg out but its like if it adjusted then it would go to 2000 then do the something and then it would go to 3.4.5. and the hole time im giveing it gas.............if thius has happen to you or if you think you know whats wrong write back
post Oct 10, 2004 - 11:40 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
you should list more stuff to help us help you
list your car st or gt, year, mods, mileage, etc...
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Oct 10, 2004 - 11:46 PM
62-1celi
Joined Sep 14, '04
From miami
its a 96 st 1.8 like 70,000 mile intake and a muffler i got the car like that and it was runing good
post Oct 11, 2004 - 12:15 AM
recneps
Joined Jul 7, '04
From charlotte N.C.
you paid 1000 bucks for a 96 st with 70,000 miles on it. and you wernt suspicious. sounds fishy to me
how did you check your fuel pump?
post Oct 11, 2004 - 1:02 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
sounds like a coil issue.. it could be the pick up coil or in could be the main coil itself. even though your getting spark the spark may not be strong enoguh. whay color is the spark? i would go to autozone i think they have the free diagnostics check. find out what it is. it could also be a clogged fuel filter, clogged pcv vlave try blowing through it......
This post has been edited by rjbibeau: Oct 11, 2004 - 1:04 AM
post Oct 11, 2004 - 1:47 AM
62-1celi
Joined Sep 14, '04
From miami
i got the car off of one of my boys mom....thats y i got it for 1g........i think it might be my injector
Lo-Fi Version Time is now: June 23rd, 2026 - 4:51 PM
