Oct 18, 2004 - 3:00 PM
Enthusiast ![]() ![]() Joined Aug 14, '04 From Toledo, Ohio Currently Offline Reputation: 0 (0%) |
So, the speed sensor from the 7afe has an electrical plug and the one in the 3S is mechanical. how did you swappers solve this problem?
the good news is, i had my mechanic open up the tranny today to check on the clutch and 2 hours later i stopped in to see a shiny blue Cusco clutch assembly complete with lightened flywheel. but on the other hand, they had to break the starter just to pull it out of the engine...no biggy |
Oct 18, 2004 - 4:00 PM
that's one fine mechanic you got there. hope they dont break parts that are more $$$ and harder to replace. -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Oct 18, 2004 - 4:06 PM
it wasnt his fault...the starter was stuck for some reason
Oct 18, 2004 - 7:02 PM
the 3sgte sensor is electronic, so is the 6th gen one.. just use the sensor thats already mounted to the tranny u will be using and it should just plug right in
Oct 18, 2004 - 9:55 PM
does it make a difference to say that i'm swapping from a jdm SW20 clip and not an alltrac
Oct 18, 2004 - 9:58 PM
here is a pic of both...on top os the 3sgte out of the mr2, the bottom is my old 7afe
This post has been edited by gtfc115: Oct 18, 2004 - 9:58 PM |
Oct 20, 2004 - 10:10 AM
anyone?
Oct 20, 2004 - 10:58 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) |
Anyone?
you? you? (bump) -------------------- ![]() |
Oct 20, 2004 - 11:26 AM
ive never done an mr2 swap, but i think you are going to need an st185 wiring harness. then your stock sensor should just plug in.
Oct 20, 2004 - 2:08 PM
know of anyone selling theirs?
Oct 20, 2004 - 2:15 PM
Keoni on celica.net said he had a camry sensor that he thinks would work. does anyone know about this? if its the same tranny then i dont see why it wouldnt work, as long as it is electronic.
| Lo-Fi Version | Time is now: May 24th, 2026 - 11:29 PM |
