> Nitrous Transfer and Legality
post Oct 22, 2004 - 1:09 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
If I got a nitrous system for my 7afe, and later swaped in a 3sgte, could I easily swap the nitrous as well? Is it practical to have a turbo car with no2?
Also, is it legal to use no2 on the street?
post Oct 22, 2004 - 1:25 AM
shid
Joined Jan 8, '04
From LA
QUOTE (CheesyLobster @ Oct 22, 2004 - 6:09 AM)
http://www.6gc.net/forums/index.php?showtopic=5574
Read my second FAQ post under the heading:
Can I use NAWWWZ (NOS, No2) with my turbo?
Short answer no, long answer yes with a but. The answer is that it is ALWAYS possible to add NOS to any car- F/I or NA. But, it's a bad idea to add NOS to a F/I (turbo'd or supercharged) car without REALLY beefing up the internals. Anyone who is familiar with NOS will tell you that in NOS, chemical formula one nitrogen 2 oxygen, the nitrogen is used as a carrier for the oxygen- and as the NOS gets "sprayed" into the air intake or the fuel system, it adds PSI to what the engine is getting.
That said, if you add NOS to a car running at 12 PSI, when you hit the NAWZZZZ button it might suddenly jump up to 18 psi or higher; pretty dangerous stuff.
And NAWZ is never legal
This post has been edited by shid: Oct 22, 2004 - 1:25 AM
post Oct 22, 2004 - 3:40 AM
Clipsetuner
Joined Sep 12, '03
From Portland , Oregon , United States
Different states have different laws on "Fuel Enrichment systems". Here you can have a Nitrous System but not the bottle hooked up, and there and stipulations to that, If you have just came from or are going to the track (same goes for slicks).
Nitrous Is gonna add that extra boost while your in vaccum but when you hit boost just gonna spool it up that much quicker, You might serveraly overwork your wastegate.
An Option perhaps is the Boost Activated switches that "NOS" the company sells. I think they come in like 7psi and 15psi switches, so when you reach that boost level the nitrous will turn off. So if your running stock psi on 3sgte, you will still have 4 more psi which the turbo would build its self. Dont know if it really works or anything but it would be worth a shot.
I plan on running a direct port System just for that extra kick. I plan to hook it up via woot switch but not hold it on very long, and if any just in third and forth.
DTE
I am a thief.
do not buy anything from me.
post Oct 22, 2004 - 3:55 AM
Doge
Joined Dec 2, '02
From Portland, Oregon
N2O isn't dangerous. You can use it on a stock motor easily as long as you make sure you are getting enough fuel... Its the dumb asses that give nitrous oxide a bad name... BOOM!! biggrin.gif
Forced Induction cars LOVE nitrous... N20 greatly reduces intake charge temps... and as we all know turbo's like to heat things up... most of the power comes from the extremely cold oxygen that the nitrous provieds the motor... It is a great addition to spool up the turbo in the lower rpms where turbo lag can be a problem... secondary benefit of N2O is that nitrogen is flamable. biggrin.gif Just keep the fuel coming and everything will be peachy.
post Oct 22, 2004 - 10:21 AM
shid
Joined Jan 8, '04
From LA
QUOTE (Doge @ Oct 22, 2004 - 8:55 AM)
Until your engine blows because it's only built for 12 psi- not the 16 you suddenly NAWZ shot into it.
post Oct 22, 2004 - 10:42 AM
hs2g
Joined Aug 26, '04
From St. Cloud, Minnesota
So is it safe to run 50shot in a stock motor?
This post has been edited by hs2g: Oct 22, 2004 - 10:43 AM
post Oct 22, 2004 - 11:06 AM
SlowCelica94
Joined Sep 28, '03
From Bloomington, IN
Yes. And you can use it on a 3s, just only a lil bit, and id recommand only when not in boost. Nitrous isnt street legal, but who's gonna know?
Ask away, I'm the local nitrous master (way better then anadason) and use to have it
92 Civic hatch B16 - Sold
10th anniv RX-7 - RIP
post Oct 22, 2004 - 11:40 PM
CheesyLobster
Joined Jul 19, '04
Thanks for the info.
post Oct 22, 2004 - 11:54 PM
shid
Joined Jan 8, '04
From LA
QUOTE (SlowCelica94 @ Oct 22, 2004 - 4:06 PM)
The problem is, when ur not at boost is when you're extremely low in the RPM range- where it's extremely dangerous to pump No2 into any engine..
It's why I've heard that any No2 + turbo setup usually uses a fairly advanced No2 setup with computer controlled systems
post Oct 23, 2004 - 12:14 AM
Doge
Joined Dec 2, '02
nitrous doesn't increase psi.. it increases cylinder pressure by adding more oxygen... therefore making it safe to add more fuel.. but you are right when you say an engine can only take so much cylinder pressure before it lets go.
post Oct 23, 2004 - 12:46 AM
shid
Joined Jan 8, '04
From LA
QUOTE (Doge @ Oct 23, 2004 - 5:14 AM)
Doge, PSI is a measurement of pressure per square inch- nitrous is adding more oxygen to be combusted- which increases psi- all the No2 is is a carrier for the oxygen- it's the exact same thing as adding instant air to your engine- in fact thats all it is.
What I'm saying is, all PSI is is a measurement of how much air your engine is getting (allowing you to add more fuel)- when No2 sprays out, it reacts and the oxygen splits off to become oxygen (u know, air) which is then combusted, just like the rest of the air. When No2 expands in the intake, it increases PSI
This post has been edited by shid: Oct 23, 2004 - 12:53 AM
post Oct 23, 2004 - 1:00 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
nitrous is legal if you get a CARB certified kit
however, it is at the cops discretion as to if you were showing off or racing.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Oct 24, 2004 - 3:49 PM
Doge
Joined Dec 2, '02
Nitrous does NOT increase psi... the main benefit of nitrous is that the oxygen in it is SUPER cold... cold oxygen contains ALOT more oxygen atoms in the SAME SPACE that ambient air would have. The pressure isnt getting increased... its just that the air that is there is getting packed with alot more oxygen due to the temperature.. NOT the compression. Which only increases cylinder pressure... not psi.
This post has been edited by Doge: Oct 24, 2004 - 3:50 PM
post Oct 24, 2004 - 8:02 PM
shid
Joined Jan 8, '04
From LA
QUOTE (Doge @ Oct 24, 2004 - 8:49 PM)
We're saying the same thing and differing on semantics; I don't care about this enough to debate pressure raises when you add molecules to an enclosed area (pressure has to raise, thats it)
post Oct 25, 2004 - 12:00 AM
Doge
Joined Dec 2, '02
no it doesn't cylinder pressure and psi are two completely different things... psi is one of the many factors in cylinder pressure.
post Oct 25, 2004 - 12:35 AM
shadycrew31
Joined Jun 29, '03
From canoga park , ca
uhh no2 blows the **** up if its under enough heat adn it also depends if you have a wet shot or a dry shot. study before you act dumb. dam doge this is the second time you pissed me off...... your starting to turn into a stupid kwanza.
post Oct 25, 2004 - 12:53 AM
Doge
Joined Dec 2, '02
I'm not trying to be cocky and act like i know everything though... the only time I get somewhat pressing with what I say is when I see something that I KNOW is wrong. I'm not calling anyone stupid or putting anyone down... I'm just making sure that the info that this kid gets is legit and not some stuff that gets made up. On that note what Shid is saying is almost right.. and i told him that... along with what was wrong about his idea of NO2. And about the whole flames thing... I'm sorry for acting stupid to do you dude, it just seemed like you jumped on that thread to dog on people... which I dont find very cool... but I could be wrong.
post Oct 25, 2004 - 12:57 AM
Fox-N-It2
Joined Jul 24, '04
From Va
QUOTE (shid @ Oct 23, 2004 - 5:46 AM)
Most people relate PSI to the amount of boost a turbo makes. You intake pressure is not signifigantly increased by spraying nitrous oxide.
N2O is sprayed into the intake and when heated(to approx 570 deg F) the oxygen and nitrogen seperate. This makes more oxygen available for cumbustions and thus more fuel must be added. Else you'll run lean and cook a piston or another important part. With more oxygen present and more fuel present durring combustion cylinder pressure is increased. High cylinder pressure and high heat is what burns up motors which is why you gotta take the right precautions when using it.
post Oct 25, 2004 - 1:01 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Nitrious doesn't increase intake pressure or charge... it has something to do with the combustion process of nitrious that is just more efficient at making power than your typical oxygen. it doesn't have anything to do with temperature either. A warm nitrious bottle is more efficient than a cold one.
Nitrious + Boost without a BUILT and TUNED motor = BLOWN ENGINE... nuff said.
This post has been edited by Kwanza26: Oct 25, 2004 - 1:02 AM
post Oct 25, 2004 - 1:16 AM
Doge
Joined Dec 2, '02
It has everything to do with temperature Kwanaza... the only reason NO2 is used is because of its extremely cold temperatures... a warm bottle is more efficient because the compressed NO2 moves more freely through the lines at a warm temp... when it hits the nozzles it instantly turns cold. You said nitrous is more efficient than oxygen in making power... when all nitrous is, is really cold oxygen and a little bit of nitrogen (which is also highly flamable [the second power adder of NO2]) COLD is the only thing that matter with nitrous.
Lo-Fi Version Time is now: May 26th, 2026 - 12:35 AM
