Oct 23, 2004 - 11:28 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
I am going to get a remote start kit for my car. I've been told that no shop will install it on my car b/c its a stick. If that is truly the case, has anyone ever installed it on their car, and if you did, can you give me a how to on installing it?
Thanks alot, Jeremy Oh yeah, whats a good brand to get. I don't need an alarm really, just the remote starter. |
Oct 24, 2004 - 3:15 AM
![]() Enthusiast ![]() ![]() Joined Sep 10, '04 From san diego Currently Offline Reputation: 0 (0%) |
hmm why not stick? what about when people all the time leave there car in gear ....will it start?
Oct 24, 2004 - 7:03 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) |
the car will not start.. but roll into a wall or another car.. ( alot of damage)
there are alot of people including myself that have install a remote start alarm in the celica. the basic wire diagram is located on the sticky at the top of the page. You will need a way to defeat the saftey clutch switch. since i own an automatic. I will leave this step to the other people on the forum to answer your question. the install is relatively simple. hook up the alarm (or remote start) wire to the coresponding wire in the celica wire harness. |
Oct 24, 2004 - 11:58 PM
so anyone with a manual celica installed a remote start on their car that can help me out??
Oct 25, 2004 - 12:12 AM
SEARCH
http://www.6gc.net/forums/index.php?showto...=remote+starter http://www.6gc.net/forums/index.php?showtopic=13685&hl= -------------------- |
Oct 25, 2004 - 8:22 AM
Enthusiast ![]() Joined Aug 19, '03 From KY Currently Offline Reputation: 0 (0%) |
I installed a remote starter on my manual transmission celica a couple of years ago. You do have ot be careful when you start it. I left mine in gear once and drove through my wife's garage door while we were dating. Her dad wasn't too happy, but what was worse was I had to help him paint the garage door again. My point is be careful or you'll mess up and have to paint garage door with your in-laws.
Oct 26, 2004 - 4:02 AM
Enthusiast ![]() ![]() Joined Aug 19, '04 From Berkeley Currently Offline Reputation: 0 (0%) |
someone on the boards made some kinda mechanism that only allowed the remote start to start if it was in neutral... but I never got so see what it was exactly..
Oct 26, 2004 - 4:11 AM
the best solution is the get an alarm with a turbo timer
so the car will run for like X amount of time after you arm it.. so when you start it, it will never be in gear. if you do this you will need to disable the safely clutch switch. |
Oct 26, 2004 - 9:24 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 25, '04 From Wisconsin Currently Offline Reputation: 0 (0%) |
and that member is the owner - Coomer back on topic: you just need a clutch bypass sensor. Theres a sensor that is activated when the clutch is depressed, this is why the car wont start unless the clutch is in, or how cruise control turns off if you press the clutch. You need to bypass this. Then, its basically just an automatic. HOWEVER!!!!! You need to leave the car in neutral, I dont think this of a problem figuring I just set my ebrake and go.... but alot of people leave it in neutral. I think Chris (Coomer) created a relay that would only let him start it if it was in Neutral. Its probably more explained in the two topics that Batman posted. -Ti |
Oct 27, 2004 - 11:20 PM
Actually I think it was trdevelopment that I was remembering, it's in this thread:
http://www.6gc.net/forums/index.php?showto...=remote+starter |
Oct 28, 2004 - 1:07 AM
Enthusiast ![]() Joined Apr 17, '04 From Southern California Currently Offline Reputation: 0 (0%) |
TRANSPONDER BYPASS MODULE
hope this helps. i bought my remote starter from this website. its really cheap. quality is good too. i have an auto but the link above has this "bypass module" that bypasses the cluth safety for stick. just be careful and make sure ur e-brake is on when ur not driving |
Oct 29, 2004 - 6:42 AM
bypass modules is used for people who upgrade there factory car alarms to an aftermarket one. This module will "bypass" the factory one and let the aftermarket one work without setting off the factory alarm. |
Oct 31, 2004 - 11:27 PM
Enthusiast ![]() ![]() Joined Aug 30, '02 From NYC Currently Offline Reputation: 0 (0%) |
get a Clifford alarn w/ remote start, they have great systems for manual.
your car can be in gear too. This post has been edited by SilverCell94: Oct 31, 2004 - 11:28 PM |
Nov 1, 2004 - 1:32 PM
what the heck are you smoking^^^^^^^^^^^^^^
think about that for a second.....with out the clutch being PHYSICALLY pushed in you CANNOT remote start your car in gear WIHTOUT rolling into sumthing/someone an manual car with remote start MUST BE LEFT IN NEUTRAL |
Nov 1, 2004 - 1:43 PM
Enthusiast ![]() ![]() ![]() Joined Jul 27, '04 From phoenix az Currently Offline Reputation: 0 (0%) |
yeh it was me guys i did have the mechanism for it not 2 start in gear but somehow it messed up the senser and now it starts up if its in gear i have to take it to my mechanic again to see what happin to it... ill let you guys know how to make one cause mine was fabricated when i get to it.
Nov 1, 2004 - 2:12 PM
sorry that doesn't sound to reliable if its messin up that bad....
i'll stick with leaving my car in neutral with the e-brake up |
Nov 1, 2004 - 11:54 PM
listen bud i ment to say the remote start was working witht he mechanism but now its not. once i find out whats wrong with that mechanism ill let you guys know but my remote start still works. |
Nov 4, 2004 - 9:13 AM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 27, '02 From Sleep in Warren chill in clinton twp, works/school in detroit Currently Offline Reputation: 1 (100%) |
Nov 4, 2004 - 11:59 AM
both of those are some b/s IMO. Any remote starter can be used on a manual. You still have to bypass the clutch sensor and neither comes with any thing to do it with.
I installed mine on sunday and it took like 1 hour to do. Very easy. I had to bypass the clutch system. My cruise control doesn't work b/c the clutch wires are touching, but I am going to buy an on/off switch that makes it work. When the wires touch, and you are in first gear, its like an automatic...Pretty cool Bottom line: Need to bypass the clutch to have a remote start in manual and leave it in neutral This post has been edited by Jeremy1210: Nov 4, 2004 - 8:13 PM |
Nov 4, 2004 - 6:19 PM
what are you talking about? clifford developed a system for manual transmissions. you CAN START YOU CAR with the caR in gear. for those who know clifford alarms they make the top of the line alarm system for cars. the local clifford dealer wil have a promotion contest every year or so. the contest, anyone who can break into the car, start it, and drive it around the block (system will stall out the car)will win whatever car they are giving out. time frame they give you 1hour well back to the subject, my girl has the system in her car (manual) and it starts it up perfectly, doesnt have to be in gear. |
| Lo-Fi Version | Time is now: August 11th, 2026 - 12:11 PM |
