> Check Engine Light
post Oct 24, 2004 - 6:56 PM
hs2g
Joined Aug 26, '04
From St. Cloud, Minnesota
My check engine light is just showed up about 2 days ago while I was driving. I thought it was my sparks plugs and maybe the car needs a tune up since it already has 75000 miles. So I called my local toyota dealer and they said that a tune up or spark plugs have nothing to do with the light. They said it was either my sensors, exhaust, or fuel. They want $75 up front too check it out and maybe some more if I want them too fix what is wrong.
I don't want to spend $75 just for checking what is wrong, but I can tell you I notice a change in gas mileage. I just pumped my gas to half tank yesterday and I only drove for maybe 30 miles on normal condition (shift at around 3k RPM) My gas went down to 1/4 tank. Thats crazy.
So does anyone have any idea what could be wrong?
post Oct 24, 2004 - 7:10 PM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
senser on the air box intake?
post Oct 24, 2004 - 7:34 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
the problems with your gas mileage scream o2 sensor
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Oct 24, 2004 - 7:42 PM
hs2g
Joined Aug 26, '04
Could you recommend me a place that can check it out or can this be done at home some how?
post Oct 24, 2004 - 7:52 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
heck engine light
That should do it..
post Oct 24, 2004 - 8:20 PM
hs2g
Joined Aug 26, '04
Hey thanks man i'll try that.
post Oct 24, 2004 - 8:40 PM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
im sure u could buy a new o2 senser and just pop it in, it doesnt look that hard
post Oct 24, 2004 - 9:18 PM
celicaboston1983
Joined Mar 20, '04
autozone do cel for free
post Oct 24, 2004 - 9:56 PM
hs2g
Joined Aug 26, '04
So you mean I can just go to autozone and have to check it out for free?
post Oct 24, 2004 - 10:02 PM
celicaboston1983
Joined Mar 20, '04
yes
post Oct 24, 2004 - 10:45 PM
hs2g
Joined Aug 26, '04
ok i'll do that tomorrow
post Oct 24, 2004 - 11:24 PM
soltrain
Joined Aug 19, '04
From Berkeley
I also read that either autozone or kragen allows you to rent OBD II (sp?) testers for free if you don't want to do the paper clip method.
This post has been edited by soltrain: Oct 24, 2004 - 11:25 PM
post Oct 25, 2004 - 2:43 PM
toyotatech3
Joined Jul 30, '04
From colorado
go to autozone and find out what code it has and let us know
post Oct 25, 2004 - 3:05 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
yes, but, lets remember that they changed codes in the mid 90's from obd1 to obd2, so depending on the year of the celica, you might not have obd2, and if you don't have obd2 autozone can't check your codes, at least not in st. louis, you can also buy code readers off of ebay. think about it, even if a code reader costs $250, you can use it over and over, and never have to pay toyota for a $75 dollar diagnostic everytime something goes wrong with your car.
but I do think that they changed it to obd2 in possibly 96? at the latest 98
post Oct 25, 2004 - 3:14 PM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
under my drivers side dash it says obd2, check there
post Oct 25, 2004 - 3:31 PM
hs2g
Joined Aug 26, '04
ok i just took my car too my local autozone today after school. They hooked this thing up too this connector under the steering wheel kind of. It read Code P0401 then says my EGA valve is not running effieciently. He showed me where is was and what I had to do. I had to take it off and clean the carbon out which might take care of it.
post Oct 25, 2004 - 3:37 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
You mean egr? cause i have the same thing. I clean out the peace with the lil filter, an carbon crap, that your saying, didnt help. I also dont wanna spend $150 on an EGR valve.. what ever..
post Oct 25, 2004 - 4:12 PM
hs2g
Joined Aug 26, '04
yea EGR
post Oct 26, 2004 - 8:49 AM
toyotatech3
Joined Jul 30, '04
From colorado
make sure the egr is not stuck closed, check for vacuum leaks, check the vacuum modulator, and then check the vsv. check the vsv when its hot becuase i had one that would work when it was cool and quit working when it warmed up. if u want info on how too check this stuff let me know.
Lo-Fi Version Time is now: May 25th, 2026 - 6:50 PM
