> Engine starts, then dies
post Nov 1, 2004 - 4:29 AM
soltrain
Joined Aug 19, '04
From Berkeley
Sadness. It's about 55 degrees outside - two hours ago I went to go watch a movie with some friends. The first time I started the car, it died almost instantly. Tried it again, with the same results. I could keep it going with some gas, but as soon as I let off, it would die. I idled it myself for a couple minutes, after which the car acted fine.
Sounds like I'm having the same type of problems as these guys -
cold start switch? vaccum leak?
http://www.6gc.net/forums/index.php?showtopic=10034
http://www.6gc.net/forums/index.php?showtopic=11899
Engine isn't too old - 70k, and up until now has been running great. What's a cold start switch? And.. vaccum leak means a line has a hole in it? Why would that fix itself after the engine warms up?
post Nov 1, 2004 - 6:46 AM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
i had same problem. .. somehing like a idle air senser intake senser .. that was replaced and no more problems
post Nov 1, 2004 - 10:51 PM
saleeka
Joined Sep 4, '03
From Twin Cities MN
thats happened to me in colder temps as well when the car has sat cold for awhile in damp air... a quick getaway has solved the problem everytime...
post Nov 1, 2004 - 10:55 PM
spunky393
Joined Apr 22, '04
From illinois
Well, i don't know about our cars, but my friend 200 SER has a cold start switch on the ecu, which you switch over to in the winter.
post Nov 2, 2004 - 5:48 AM
soltrain
Joined Aug 19, '04
From Berkeley
hmm, i forgot to also say that according to my friends standing outside, there was a pretty strong smell of gas. Most likely from my partially flooding the engine trying to start it right?
post Nov 2, 2004 - 10:12 AM
this seems to be a very common celica issue. check your egr system and make sure its not cloged. aslo, check to make sure there arent any loose or cracked vac lines.
Lo-Fi Version Time is now: September 2nd, 2026 - 8:08 PM
