> Tire pressures
post Nov 28, 2002 - 4:10 PM
jontechie
Joined Oct 25, '02
From London- England
What pressure do you run your tires at?.I had a flat the other day
and the local garage plugged it with a rubber pellet and sent me on my way. I thought the tire looked over inflated so
checked it a couple days later, it was at 65 psi !!
I normally pressure at 35psi for 17" rims. toyota's psi
standard is for a 14" rim, so do you ideally alter it as the rim gets bigger?
Replies (1 - 12)
post Nov 28, 2002 - 8:11 PM
macavely
Joined Nov 4, '02
it should say the psi you should use on the side of the tire. but as for my stocks i use 40psi,
post Nov 28, 2002 - 9:03 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i use 35psi on my 17X7.5
post Nov 28, 2002 - 9:16 PM
SiKBOY
Joined Nov 4, '02
From Sydney, Australia
I think the fronts should be higher than the backs because of the weight difference between the nose and the rear. That is only if your super picky about that kind of stuff. On the track I'll probably set my tires (on 17x7) to about 44 PSI only because you want that sidewall stiffness and also the roads on the track are super smooth. On the street I have it on about 36.
post Nov 28, 2002 - 10:06 PM
macavely
Joined Nov 4, '02
just remeber that air expans when it get hot so don't over inflate
post Nov 29, 2002 - 2:10 AM
iceman23
Joined Oct 25, '02
From Tokyo, Japan
I keep mine at 36 psi as well. You're lucky your tire didn't burst at 65psi.
post Nov 29, 2002 - 1:04 PM
Zoom
Joined Oct 15, '02
From Rochester, New York
That would be funny, I'd laugh;)
post Nov 29, 2002 - 1:42 PM
Popping tires is very dangerous. My mom's friend over-inflated a tire and the tire popped so loud that it made him go completely deaf.
post Nov 29, 2002 - 7:20 PM
CDNSLEEKA
Joined Sep 16, '02
From Yarmouth,N.S Canada
Zoom you have a sick sense of humor! I go with 35psi (17x7)
post Dec 1, 2002 - 2:24 PM
BigEdge169
Joined Nov 18, '02
From Texas
On my last set of tires (Yokohama Parada 215/40ZR-17), I kept the pressure around 40psi because that's what the manufacturer recommended. However, they wore unevenly (the middle was gone before the sides) so I suggest around 35 or so.
post Dec 1, 2002 - 10:51 PM
Mizuryu
Joined Nov 8, '02
From Mongtomery Alabama
i've got 36...and ya are pretty lucky ya dind't have a blowout...those freakin' things suck
post Dec 2, 2002 - 7:11 AM
yel094
Joined Nov 18, '02
Yeah, mine sit on 38 front and 36 rear...
Interesting that us guys from Syd in OZ run the front higher.
post Dec 7, 2002 - 1:17 AM
coolspotz
Joined Sep 24, '02
QUOTE (yel094 @ Dec 2 2002, 05:11 AM)
Why do we ( i come from syd as well) need higher psi for fronts ?
..i am using 35psi all round..
Lo-Fi Version Time is now: August 24th, 2026 - 2:39 PM
