> camber kits, possible camber kit
post Nov 15, 2004 - 10:18 PM
samguglielmo
Joined Nov 2, '04
From Georgia US
Not able to get the info Im looking for. Trying to find out, at what point will a person need a camber kit confused.gif . Ive got 18 on my celi and getting ready to lower with coilovers and also trying to decide which struts to get with roughly a 2" drop out of the coilovers.If anyone could help I would be greatly appreciate it. If a person does need to order a camber kit where would that be found.Thanks again biggrin.gif
Replies (1 - 5)
post Nov 16, 2004 - 12:15 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
2" drop is a lil high your gonna be bouncin like a honda with that drop.
post Nov 16, 2004 - 2:11 AM
Junior
Joined May 5, '03
From Toronto
I got close to 4 inch drop with GC's. My camber is really good and I don't need a kit. Negative camber is good for cornering, but it will wear the tires a bit. Find the right camber to give you the balance you want. But I'm happy with the camber I got.
post Nov 16, 2004 - 9:38 AM
mikew04
Joined Feb 19, '04
From austin tx
Either way, get your car aligned after you drop it.
post Nov 16, 2004 - 10:33 AM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
You dont need your car aligned, unless your un-bolting to much.. your not touching the settings, and if you know what your doing, theres no reason to spend the money. I droped mine, and its still perfect. and norm is sugested to use a camber kit, anywhere from a 2-4 inch drop. thats just so you have a perfect camber.. and unless you wanna ware your rubber pre.
post Nov 16, 2004 - 7:17 PM
Junior
Joined May 5, '03
From Toronto
QUOTE(Digndoug @ Nov 16, 2004 - 8:33 AM)
[right][snapback]207548[/snapback][/right]
Your allignment will be off. It has nothing to do with touching settings. And perfect camber is not what you're looking for. Stock cars come with negative camber for a reason. As you move into turns, the camber starts to increase (get more positive) so you start with negative camber and get closer to zero camber while turning.
Lo-Fi Version Time is now: August 9th, 2026 - 9:17 AM
