Nov 18, 2004 - 9:51 AM
Enthusiast Joined Oct 28, '04 From Toronto, Canada Currently Offline Reputation: 0 (0%) |
Just bought a 95 Celica GTS for my wife(she can't drive my 92 Alltrac,hehe). I'm trying to install a Prostart 3 in 1 CT-5000 and I'm a bit confused a few issues. My manual asks for +12 V battery(red wire) and says"Connect to the largest 12 V supply wire at the ignition harness. Ensure that the power wire is fused for more than 30A" Now I spliced it into the black with red wire, but their website says white and I think the12volt.com says white. I think on this forum it says black with red. Which one is it?
Lor 92 Alltrac 95 GTS Toronto, Canada |
Nov 18, 2004 - 9:54 AM
Nov 18, 2004 - 10:31 AM
That's where I looked and it says the opposite of what the other 2 sources say. That's why I need clarification and an absolute answer.
Nov 18, 2004 - 10:37 AM
This is from the Manuf. website
+12 Volts White Ignition Harness + Ignition Black/orange Ignition Harness + Ignition 2 Blue/red Ignition Harness + Starter Black/white Ignition Harness + Tachometer Gray IG (-) pin on diagnostic plug AC Lock Blue/black or Blue Module to right of steering column - Unlock Blue/red Module to right of steering column - Doorpin Red/white In driver's kick - Brakeswitch Green/white At brake pedal switch + Parking Lights Green at dimmer + Trunk Pin N/A N/A - Trunk Release Add Solenoid N/A N/A From the12volt.com Constant 12V+ White Ignition Switch Harness Starter Black/White Ignition Switch Harness Ignition Blue/Orange Ignition Switch Harness Ignition 2 Blue/Red Ignition Switch Harness Tach White/Blue Or Black (-) at Diagnostic Connector or Igniter Brake Switch Green/White Brake Switch Trunk Pin Red/Green (-) Driver's Kick Harness Parking Lights Green Dimmer or Fuse Panel Head Lamp Red/Black (-) Light Switch Door Trigger Red/White (-) Driver's Kick Panel Door Lock Blue (-) Door Lock Module right of Steering Column Door Unlock Blue/Red (-) Horn Wire Green (-) Steering Column Windows Up LF=Green, RF=Green/White LR=Green/White, RR=Green Windows Down LF=Red, RF=Red/Blue LR=Red/White, RR=Red Lor 92 Alltrac 95 GTS Toronto, Canada |
Nov 18, 2004 - 11:39 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 16, '02 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
Nov 18, 2004 - 11:46 AM
Thanks, So this shows:
12 VOLTS CONSTANT BLK/RED & WHT IGNITION HARNESS A combination of both, confusing again. Lor 92 Alltrac 95 GTS Toronto, Canada |
Nov 18, 2004 - 11:54 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
http://www.6gc.net/forums/index.php?showtopic=16174
its got a pic and detailed info provided by coomer, i used it when installing mine it its great. And if u still don't get it run a independent wire from battery to alarm its easy. -------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Nov 18, 2004 - 12:36 PM
Thanks. This is the one I originally went by, but then the other sites messed my mind up,lol.
Hopefully I can finish it up this weekend. Lor 92 Alltrac 95 GTS Toronto, Canada |
Nov 18, 2004 - 4:41 PM
What you really should do is test the wires yourself. Then you can be absolutely certain.
Nov 19, 2004 - 10:03 AM
Wire testing makes sense. Measure twice cut once, right?lol. Thanks everyone.
| Lo-Fi Version | Time is now: August 4th, 2026 - 10:09 AM |
