Nov 23, 2004 - 10:11 PM
Enthusiast ![]() ![]() ![]() Joined Aug 18, '04 From St. Louis, Missouri Currently Offline Reputation: 0 (0%) |
where can i get them the cheapest? also, are they just bolt on or do i need modifications? id rather just have them bolt on if possible.
Nov 23, 2004 - 11:05 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 12, '03 From Crestview, Florida Currently Offline Reputation: 2 (100%) |
www.procarparts.com carrys sets of both together.
http://www.procarparts.com/store-detail.as...e=onlinestoreDB theres a direct link. its around 55$. This post has been edited by BLINKYxMUNKEY: Nov 23, 2004 - 11:08 PM -------------------- |
Nov 25, 2004 - 11:35 AM
anyone have any install pics? they look like they would be kind of weird.
Nov 25, 2004 - 11:53 AM
Enthusiast ![]() ![]() ![]() Joined Aug 30, '02 From North Carolina Currently Offline Reputation: 0 (0%) |
i had them on my celi. Here are some pics
adam -------------------- MISS THE CELI, BUT...
Nov 25, 2004 - 4:56 PM
Enthusiast ![]() ![]() Joined Dec 24, '02 From Wirral, UK Currently Offline Reputation: 0 (0%) |
jesus .. don't spend $55.. just 1 min in a warm oven will make the front ones clear..
to make your facelift indicator lights clear. get a small philips head screw driver - you'll need this later. 1. take the indicator lights out of the bumper. 2. heat the oven upto about 200 deg c. (gas mark 6) 3. put the light on a baking tray - put in the oven for about 30 seconds. 4. take the lights out of the oven. Prise of the clear front lense (the glue will be soft) 5. you will see an orange square lense. this is held in place by a small philips screw. remove it. 6. do the other light cluster. 7. put the parts back onto the tray and heat them again for aout 15 seconds. 8. remove them from the oven and push the clutser back to gether again so the glue seals them again. 9. Let them cool 10. Using a kebab stick or similar implement, use a pieve of absorbent paper to soak up any condensation or moisture in the lense. 11. you mith want to use soem clear sealant to just seal the edge. 12. using either orange bulbs, but preferably silver vision ones, replace the cluster. all done - looks cool ! 30 mins tops ! for the side ones just get some avensis or corolla side repeaters from MrT. costs about £10 over here - so maybe $20 there. again get type 194 silvered bulbs that flash orange.. btw you do this at your own risk - if you neeed adult supervision ask for it ! don't try and sue me cos you damage yourself or something !! |
Nov 25, 2004 - 7:41 PM
if i do this: http://www.6gc.net/index.php?action=howto&itu=12
do i use the same bulbs or what? -------------------- |
Nov 25, 2004 - 7:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 3, '04 From Yakima, WA Currently Offline Reputation: 1 (100%) |
so those clear turn signals on procarparts fits on 94-95? i dont think it looks like it will.
-------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Nov 25, 2004 - 10:21 PM
it says 96-99 in the link
Nov 25, 2004 - 10:43 PM
94-95 different than 96-99. There are no aftermarket turns for the 94-95. Just the side markers.
| Lo-Fi Version | Time is now: September 12th, 2026 - 6:15 AM |
