> Fiber glass, what kind and where at?
post Dec 2, 2004 - 8:29 PM
urbandork
Joined Jul 16, '04
From Los Angeles
Im planning on using fiberglass for a custom sub enclosure. Where do you fiberglass ppl get the stuff to lay the fiberglass? Ive seen some kits from Bondo but have been thinking about looking into stuff for boats.
Also when using it for a sub box should i use the one thats weaved one way or both ways. And about how many layers should i put if i use the single weaved one or double weaved one?
I know some tips like use foil to mask things off. Use vasoline on gloves and use a mask to breath and good ventalation. BUT what other tricks of the trade are there that make the job a bit easier?
Thanks a bunch a munch
post Dec 2, 2004 - 9:04 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Theres two simple types of resign, theres epoxy and acrilic. acrilic is going to be muhc much cheaper, and will work perfect for a sub enclosur. Your best bet would be to go look at a boat yard. if there not one near you, just go to home-depot, its like $25 for a gallon. I would also say use double woven material, it will be stonger work nicer with the box. You wanna have at-least 3 solid layers. Theres no reason to do anymore. Some other tricks would be to, take your time, and use cheap brushes. Liek go to a dollar store, mine is 3 for a buck. also get a big box of laytec gloves.. you'll use a lot.
post Dec 3, 2004 - 1:54 AM
yea mask is good
i'd suggest 4 layers
go:
mat
cloth
math
cloth
that if you pushing sum good stuff
thats what i'm doing at least
umm get online and search for BULK fiberglass that you can order
home-depot is just too expensive......
post Dec 3, 2004 - 1:13 PM
urbandork
Joined Jul 16, '04
From Los Angeles
Cool. THanks for ur help. If anyone else has anything to add fell free to do so.
post Dec 4, 2004 - 12:48 PM
urbandork
Joined Jul 16, '04
From Los Angeles
where would i get the fiber glass matterial? Would home depot carry it?
post Dec 4, 2004 - 2:01 PM
Gilbert_619
Joined Sep 10, '04
From san diego
home depot has it but expensive
try a marine place like boat place..the tend to have alot for cheap
http://web.njit.edu/~cas1383/proj/main/
try that link it will help you understand the basics of glassing
post Dec 4, 2004 - 7:20 PM
Junior
Joined May 5, '03
From Toronto
a boat shop or a automotive paint supplier should have everything you need.
post Dec 4, 2004 - 11:46 PM
urbandork
Joined Jul 16, '04
From Los Angeles
thanks everyone for the links and advice it helped a lot.
Lo-Fi Version Time is now: August 4th, 2026 - 12:02 PM
