Dec 7, 2004 - 12:07 AM
who has custom boxes that the did their selves outta fiberglass?
how much glass did you use? how many layers? what was your cost? did you buy rings or make them? did you use wood/mdf at all? bodyfiller? This post has been edited by playr158: Dec 7, 2004 - 12:08 AM |
Dec 7, 2004 - 12:55 AM
Enthusiast ![]() ![]() ![]() Joined Sep 6, '03 From hudson ,iowa Currently Offline Reputation: 1 (100%) |
one for the celica with 2 12's and amp flush in middle , couple for fulsize chevys , cougar and fullsize ford with 4 12's,
1. depends on box more than a gallon 2.lots works good to lay first lay with fleese and sok in resin , then build off that , build layers inside if possible saves alot of time less sanding and can be layer on as thick as you want without losing the shape 3.$20 a gallon for resin plus filler amd i had mdf from other boxes 4. can buy but if you use 10''s home depot has 11'' 3/4 thick disk of wood that work nicely just cut out center, makign them isnt to hard but harder to get good circle "or i just cant cut strait" 5.mdf frame and sides with glass top is what do most the time 6. is a must , i use cheap walmart brand bondo , works good , , if you want pics or more questons ask |
Dec 7, 2004 - 1:34 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 10, '04 From Shoreline, WA Currently Offline Reputation: 4 (100%) |
I have one that once painted will be a perfect mold to the driver side of the trunk, its for 2 competition 10".
1. Yeah it all depends on how many layers you do and how big it is (obviously) I mush have gone though a gallon at least, maybe 2 2. it varies, i did 6 on the base (part that bults to the side) and around 4-5 over the rest I used the mesh, not the mating for extra strangth so i did not have to do so many layers. 3. yeah what pxcr440 said, about 20 a gal, + $6 per yard and a half of mesh, i used about 5. 4. I took the rings from my mdf box i had maid a wile back, you can buy them and maybe its a good idea, but i maid mine and it worked just fine. 5. mdf for the ring, but thats all, wood dowel to hold up the rings in place for the first few layers over the frunt. 6. Yep a good amount of body filler to even out the surface, rather then sanding the fiberglass and making it thiner, plus its easery to smooth out body filler (i have in the pased used fiberglass reinforced bondo but its not the best stuff, it takes for ever to dry and is hard to sand evenly. regual is the best. This post has been edited by creis: Dec 7, 2004 - 1:36 AM -------------------- ![]() |
Dec 7, 2004 - 1:35 AM
yea i'm making 2 12" audiobahn in my trunk....facing the hatch angling in towards the center of the car a little bit, with the battery in the middle and the amp on the face of the box at the same angle as hatch glass.....
using fiberglass to make the mold of the bottom, back and sides...then using t-shirt to make the front.... 1 farad cap..400watts rms for each sub and 800rms amp..... weeeeeeee and hopfully an optima yellow top |
Dec 7, 2004 - 1:38 AM
i'm gana be running my 2 audiobahn 10's (450 rms) with an audiobahn A8002T amp (400 rms per chenne(2)) plus i'm getting a optima red top and i have a boss 1 fard cap
Dec 7, 2004 - 1:44 AM
yea i already have a a8002t
but 1 cannel 800rms...lol but i'm goin to use a splitter and split it instead of 2 channel cause my audiobahn 12s are 400rms at 4ohm |
Dec 7, 2004 - 10:10 PM
Depending on your style, you might not be able to use wood at all. I would sugest if you can, use as much wood as possible, it will be a lot easier. I used bout 4 or so layers on mine, an its perfect. Im going to finish it with in this week. Il try an post some more pics. But just be patiant and dont rush it.
Dec 7, 2004 - 11:15 PM
i hate wood......not very professional i don't realy know any pros that use wood unless its a box, or a ring....for my design its light wieght and curvy for the most part......that and fiberglass is actually easier for me since i dont have to cut
Dec 8, 2004 - 5:03 AM
Enthusiast ![]() ![]() ![]() Joined Mar 9, '03 From Orting, WA Currently Offline Reputation: 0 (0%) |
im putting fiberglass over my wood. its real easy, and i can then shape and mold it a lot better. basically i just took my box, fiberglassed over it, then molded it into the trunk, well thats my plan.....
Dec 8, 2004 - 10:10 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) |
i have GOT to sell my system, the amps getting too popular
Dec 8, 2004 - 11:52 AM
QUOTE(playr158 @ Dec 8, 2004 - 4:15 AM) i hate wood......not very professional i don't realy know any pros that use wood unless its a box, or a ring....for my design its light wieght and curvy for the most part......that and fiberglass is actually easier for me since i dont have to cut [right][snapback]218364[/snapback][/right] Ummm Most professionals use wood, because its going to give you very easy deisgning and cut the time in half. but yes they also use fiberglass. forexample, "Pimp my Ride" more then half the boxes they use are made with wood, and the other half are all wood. Lot chepaer and less time consuming. |
Dec 9, 2004 - 1:21 AM
pimp my ride WTF thats the gayest junk ever....
wood weights more..... and it would only be good for the oh nothing in my setup |
Dec 9, 2004 - 2:51 AM
Enthusiast ![]() ![]() Joined Nov 8, '04 From Carmi, Illinois Currently Offline Reputation: 0 (0%) |
ive never used fiberglass, but id rather use 3/4" MDF than fiberglass personally, ive seen installs with fiberglass crack and break, plus to me MDF puts off better resonance. but thats just me, plus fiberglass takes time and money. you wont see spl compititors get high db's using fiberglass. its mostly for looks anyway.
-------------------- i want a stereo so loud, it blows womens clothes off.
TrickedOutS2000: I just opened a box that arrived on my doorstep cuz i thought it was my H.U. TrickedOutS2000: it was a vibrator my dad bought scarr3ll: WHAT THE ****?!?11 TrickedOutS2000: yeh TrickedOutS2000: for my mom im guessing TrickedOutS2000: but yeah TrickedOutS2000: eww TrickedOutS2000: so TrickedOutS2000: ****ing TrickedOutS2000: wrong My Cardomain Page. Car Audio Central msn: jared_s_c@hotmail.com aim: Scarr3ll |
| Lo-Fi Version | Time is now: August 26th, 2026 - 9:28 PM |
