> pics of antenna switch
post Dec 12, 2004 - 10:02 PM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
anyone have some? im looking to do this but i need some ideas on the type of switch, location, etc. also, the wires i cut have to go from the hu to the switch and from the switch to the antenna, right? i dont really understand how to install the switch.
post Dec 13, 2004 - 2:24 PM
C3L1CA
Joined Mar 11, '04
From Oakdale, MN
I don't know how to set up the switch because I don't have a power antenna. But I like where my switches are. I just got them from a hardware store and they work really good.
This post has been edited by C3L1CA: Dec 13, 2004 - 3:37 PM
-Brad
01 a4: daily
post Dec 13, 2004 - 3:13 PM
tim86
Joined Oct 31, '03
From Orlando, Florida
cool... i like that setup too
post Dec 13, 2004 - 5:31 PM
rocky2006
Joined Aug 18, '04
all the switches at my small hardware store are 120v. does that mean its rated for 120v or it can only be 120v? also, can someone with the power antenna clear up the wiring issues? after thinking about it, do i just leave the headunit wires hanging (but taped up) and connect the power antenna's positive and negative wires to the switch? C3L1CA, what did you use to make the square holes for your switches or are they actually circle holes?
post Dec 13, 2004 - 5:53 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(rocky2006 @ Dec 13, 2004 - 4:31 PM)
[right][snapback]221026[/snapback][/right]
the switches will work just fine and you can wire it either way but it'll be much easier to use the wire from the head unit.
Edit: if the switch has a light and is rated for 120V then the light isn't going to work.
This post has been edited by WannabeGT4: Dec 13, 2004 - 5:54 PM
post Dec 13, 2004 - 7:22 PM
C3L1CA
Joined Mar 11, '04
From Oakdale, MN
-Brad
01 a4: daily
post Dec 14, 2004 - 3:13 PM
eclipse_04a
Joined Aug 22, '04
From Menomonie, WI
i would wire it through the head unit, because then all you have to do is splice a switch into the line, and when the power is connected, and switch is on, the HU will do it for you, and if you dont want the antenna up, just flip the switch, and the HU wont put it up when it wants it up... just alot easier if you ask me.
post Dec 14, 2004 - 4:09 PM
rocky2006
Joined Aug 18, '04
if i just splice it, then the hu will always control it because there will always be the connection.
post Dec 14, 2004 - 4:29 PM
no if you splice the power between the HU and the antenna then the HU is on and the switch is off haha no power to antenna which means down wink.gif and then when you flip the switch on with the HU on then WALA its goes up wink.gif
post Dec 14, 2004 - 8:49 PM
rocky2006
Joined Aug 18, '04
i was mistaken on what he meant. i thought he meant splice as in intall the switch between the antenna and hu on the wire while the wire is still intact. whenever i use the word "splice" i usually mean to add another wire to the existing wire while leaving a connection in the original wire. sorry for the misunderstanding.
from the diagram, how should i wire it up?
This post has been edited by rocky2006: Dec 14, 2004 - 8:58 PM
post Dec 14, 2004 - 11:39 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
post Dec 15, 2004 - 12:19 AM
rocky2006
Joined Aug 18, '04
so im guessing i cut the blue wire at the back of the hu and put the switch in there? why did he say to cut the red and black wires in the how-to? is his way to have the antenna up or down with total control while your way is either antenna down or hu taking control?
post Dec 15, 2004 - 12:45 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE(rocky2006 @ Dec 14, 2004 - 11:19 PM)
[right][snapback]221604[/snapback][/right]
Exactly.
post Dec 15, 2004 - 1:15 AM
just to put it clearly, when you turn the HU on the antenna goes up. Off and it goes down. Now if you put a switch / interupter on the blue wire, if the HU is on and antenna is up, hit the switch and antenna down. The switch cuts power to the antenna, telling the antenna motor the HU is off and retracts the antenna.
When I listen to CDs I hit the switch and the antenna goes down. I have a little switch under the dash. Nothing special about it. I did this when I put in a power antenna on my ST biggrin.gif
post Dec 15, 2004 - 11:13 PM
rocky2006
Joined Aug 18, '04
ok, i just have to make sure i put the switch on the antenna side of my remote wire or else my amps will shut off too biggrin.gif. dont want that.
This post has been edited by rocky2006: Dec 15, 2004 - 11:14 PM
post Dec 16, 2004 - 9:26 PM
rocky2006
Joined Aug 18, '04
i put the switch in today. i use one of those rectangular switches and put it on the right side under the steering wheel. theres a little plastic cutout on both sides for switches. it looks like part of the car.
post Dec 17, 2004 - 3:27 PM
eclipse_04a
Joined Aug 22, '04
From Menomonie, WI
lol, my head unit puts the antenna down on its own when i switch it to cd....or standby, or anything but radio smile.gif but for a $1000 head unit, it better at least do that....
post Dec 17, 2004 - 9:36 PM
rocky2006
Joined Aug 18, '04
uh, my stystem was $1000 biggrin.gif. well let me figure it out: hu $170 on sale, speakers $150 for all 4 on sale, eclipse amp $200 on sale, Infinity 1230W's and box $170 used for 1 week (mint), sub amp $140 on ebay. TOTAL: $830+wires. retail is $1450. i dont even want to know how much your system was... (yes i do biggrin.gif)
This post has been edited by rocky2006: Dec 17, 2004 - 9:39 PM
Lo-Fi Version Time is now: August 11th, 2026 - 9:40 PM
