Dec 13, 2004 - 12:45 PM
Enthusiast ![]() ![]() Joined Jan 17, '03 From Fresno, CA Currently Offline Reputation: 0 (0%) |
i having trouble with my stock seat right now. The problem is that the passenger side don't side back and forth. Do anyone have the same problem? need help..
or i will have to take out the seat and try to fix the problem. |
Dec 13, 2004 - 1:55 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 25, '02 From Pittsburgh/Clairton, PA Currently Offline Reputation: 1 (100%) |
check the tracks, maybe a screw got in there...
that should be the main prob, if it's not even beginning to budge, check the level that unlocks it, it may be broken -------------------- ![]() |
Dec 13, 2004 - 3:00 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 22, '03 Currently Offline Reputation: 0 (0%) |
^^^^Consynx is right.
Mine was stuck also. Found out a penny was stuck in the tracks. |
Dec 14, 2004 - 3:15 PM
Enthusiast ![]() ![]() Joined Aug 22, '04 From Menomonie, WI Currently Offline Reputation: 0 (0%) |
if it hasnt been moved in a long time, then it could be rusted. if it happened suddenly, then i would say somethings in the track, and last case....the lever broke like stated above.
Dec 20, 2004 - 11:16 PM
how do u take off the seat...i know that they are two bolt in front but where are the rest of the bolts?//
Dec 20, 2004 - 11:19 PM
Enthusiast ![]() ![]() ![]() Joined Nov 14, '04 Currently Offline Reputation: 0 (0%) |
there are two bolts in the front like you said and then another two in the back that have plastic covers over them. Might be a pain to see them depending on where your seat is stuck at.
| Lo-Fi Version | Time is now: August 9th, 2026 - 4:16 PM |
